Suddenly No Heat- update
Old Jan 18, 2012 | 03:19 PM
jim993's Avatar
jim993
Default Suddenly No Heat- update
I should have reported this earlier.
About a year ago I was on my way to work on a cold morning and found that I had NO heat.
After waiting for a bit and resetting the temperature ****, the heat came on.
It happened again on another day.
No HVAC codes.
I later found at Corvette Action Center, under Knowledge Base, 1997-2004, Heating and Ventilation, a service bullitin which indicates that for 1997-2003 vehicles, turning the temperature **** in a rapid manner can confuse the HVAC controller.
I now turn the temperature **** slowly to the desired temperature, no repeat of the problem in over a year.
Old Jan 18, 2012 | 04:02 PM
FormerlyFiero's Avatar
FormerlyFiero
Oldtimer
My '97 standard HVAC control takes 15-20 seconds to figure out where the dial is pointed in the morning, just blows air everywhere. (Like it did before I got the under the battery lines fixed). I just figured it was a quirk, now I found out it's model year specific. Like most things I bet it's more prevalent on the earlier models.
Old Jan 18, 2012 | 04:05 PM
El original's Avatar
El original
Thanks for letting us in on it. (Seems once we get the problem fixed most dont share the solution). Rob
Old Jan 18, 2012 | 04:33 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Thanks .......that's a new one for me. Appreciate the heads up.
Old Jan 18, 2012 | 05:12 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Very interesting information. I get confused as well if I move too quickly.
Old Jan 18, 2012 | 06:17 PM
jim993's Avatar
jim993
Semper Fi
Old Jan 18, 2012 | 09:07 PM
memmer's Avatar
memmer
My thanks to you also.I drive aroadster and never put the top up,so the heater is a blessing.
Fred
Old Jan 18, 2012 | 09:22 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
I have never noticed this issue as I have mine set to Auto 74 deg year around and I never change it.
Old Jan 18, 2012 | 11:27 PM
Good information to know. Thanks.
To Suddenly No Heat- update
