Electrical issues...help
Old Jan 20, 2012 | 04:36 PM
ebabz's Avatar
ebabz
Default Electrical issues...help
So the footlamps for both the driver and passenger side do not work and I don't know what the fuse number is to change it. Also my rpm's do not work... they don't go up when I am revving the engine... any ideas?? Thanks for any help!
Old Jan 20, 2012 | 05:21 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I don't have the wiring for your car but per my owner's manual for a '99, micro relay #42 is for the courtesy lamps. You might want to check all of your fuses, possibly pull the cover from the relay and manually close the contacts. Someone with the wiring will be able to better assist you.
