2000 Coolant Fan
Old Jan 22, 2012 | 01:55 PM
Koukla's Avatar
Koukla
2nd Gear
Default 2000 Coolant Fan
New to the forum although I've had the Corvette for a few years now. Woman needs help! Is there a way to check the motor of the coolant fan assembly? The fan blade is broke and the motor won't turn on. I was hoping I could just change the fan blade wheel? and not motor.
Thanks!
Old Jan 22, 2012 | 02:28 PM
dougbfresh's Avatar
dougbfresh
Doubt you'll just find the fan as a spare part anywhere.
Old Jan 22, 2012 | 02:40 PM
damilleniumboy's Avatar
damilleniumboy
There are two fans, and they are together in a housing. To turn them on to check them, turn on your A/C at the cold setting, and they should both turn on. Never mind, I found them on fleeBay.
Here are the links.
http://www.ebay.com/itm/02-Corvette-...item415ab70990
http://www.ebay.com/itm/01-Corvette-...item4155f34d13
http://www.ebay.com/itm/97-04-C5-Cor...item588e188263
Old Feb 22, 2012 | 10:16 PM
Koukla's Avatar
Koukla
2nd Gear
Default Overheating!!!!!
Ok so 3 mechanics later!??? Replaced 3 relays, 3 fuses, coolant sensor, thermostat, and the coolant fan assembly. Still gets hot........After about 30 minutes if I'm at a light or in traffic (daily)I have to turn the heat on and the temp goes down to between 195 - 200. Once i'm on hwy or steady driving temp goes down to 185???? Any advice would be appreciated...... Ive noticed when I turn the ac on both fans will come on. Are both fans suppose to cycle from high to low or just the one ac fan?
Old Feb 22, 2012 | 11:21 PM
Toolmandbq's Avatar
Toolmandbq
I had a problem like this on a car (not a vet)a few years ago. The problem got so bad, I had to take the radiator out and thats when I found the problem. It looked clean on the front of the radiator and on the AC coil, but between the two was a different story. It was plugged with dirt and leaves. On my 2000 vet I did not think my AC was working right, so the first thing I did was really clean the coils. I got the car up in the air enough so I could get at the radiator and really give it a good cleaning. I spent a good 15 minutes and yes,I did get wet, but It help out alot.
To 2000 Coolant Fan
