Can you identify these swaybar endlinks? I bought them on the auction site and they were described as 97-04 C5 end links and were off a 2000 with 6k miles. I assumed they were OEM parts but when they arrived I thought otherwise. They are quite heavy and I'm sure will do the job just wondering about their origin.
I also got these bolts with the rear endlinks, any ideas on these? The bolts are 7" long with poly bushings and self locking nuts.
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Originally Posted by Jewjenk
The endlinks look like the adjustable ones, might have to get some specs on how long they should be.............
They are adjustable. On install count the threads showing and make sure you start out the same on both sides, then tighten down equally on each side. WD40 for the install no grease. These types are designed to run "dry". Over a year and no squeaks on mine.
Leprkon,,,what is the damn brand name,,,I can't remember,,,,,
Thanks Leo!
OP, see above!
