Help 2002 Corvette
Old Jan 24, 2012 | 11:20 PM
Mrleeks's Avatar
Mrleeks
Cruising
Default Help 2002 Corvette
I recently purchased this vehicle and it has a set of Z06 Wheels on the car except they are all 18 inch wheels. The tire size in the rear is a 295/30/R18 and the Front tires are 275/35/R18. I took the car into the dealership for the car shaking for a few seconds when I give it gas anywhere above 60 mph. After that few seconds it goes away. They told me that the owner before me put wrong size tires on the car which is why the car shakes. Has anyone had this issue before? Are these tires too big for the non Z06 Corvettes? Please let me know if you have any information.
Thanks Derrick
Old Jan 25, 2012 | 12:07 AM
alankb's Avatar
alankb
I think you should stay away from that dealership and find a reputable tire shop to balance your tires! Just my 2 cents..
Old Jan 25, 2012 | 01:09 AM
skeet's Avatar
skeet
That certainly is not the reason the car shakes!
Maybe the wheels are not true or the tires slipped a ply.
How many miles on this car?
Bushings, shocks or balance of tires can be a factor but not the size or 18: wheels all around.
I was thinking of putting 18" tires all around onn my C5 Z06 and my 2001. Do they stck out of the fender wells?
A photo would be appreciated.
I also agree alankb -- stay far, far away from that dealer.
Old Jan 25, 2012 | 01:27 AM
01magnetic01's Avatar
01magnetic01
Hey Derrick....good answers above, could be a bent rim or alignment as well. The idea of larger wheels making any kind of an affect like that is bs. A lot of people both here and that you saw at the Abels toy run have plus1 or plus2 sizing on their wheels. As stated above a good tire shop will usually determine the cause.
Old Jan 25, 2012 | 01:43 AM
skeet's Avatar
skeet
8Vette7 - good point and a good possibly but cann't you find out if that is the issue by turning off the AH and TC ( either with the competition buttom or with a fuse)?
Old Jan 25, 2012 | 02:23 AM
BOUT X's Avatar
BOUT X
Corvette Cowboy
Derrick
Give Richie a call at Abel Chev. in Rio Vista he can help you out with any problem they are the #1 Corvette shop in the area
Pops
Old Jan 25, 2012 | 08:47 AM
roscoe118's Avatar
roscoe118
Originally Posted by 8VETTE7
I disagree with both of the above responses.
...The vibration that you are feeling is the AH trying to take control because the rear tires are spinning from it's point of view...
Wouldn't the "Active Handling" message appear on the DIC if this were the actual cause. I'm not disagreeing with you, as these actual tire sizes should confuse the he!! out of the AH system. But, with no message, I'd lean towards an out of balance tire/rim issue.
OP, if you do in fact have 295-30-18's out back, you should really replace them with 295-35-18's to work properly with the size you are running on the front...
Old Jan 25, 2012 | 09:21 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Unless the wheel size was changed in the computer, the system will indeed cause problems with the AH and traction systems. People cannot just change the wheels and go on their merry way. The software was written in specific ways for specific reasons and the wheel size ratios were done for a specific reason...and no, I don't know the reason but I do understand the engineering of the supporting systems. The OP needs to see the programming of the computers first to determine if a change was made in there.
Old Jan 25, 2012 | 09:55 AM
3sACROWD's Avatar
3sACROWD
Are you certain the rear tire is 295/30-18??? Might it be 295/35-18???
If the tire sizes you stated are in fact what is on the car then there IS a problem that the tire sizing would be causing.
A general rule of thumb is that for C5's that have both AH and TC (all C5's 2001 and newer) the rear tire overall diameter should be at least 1/2" larger overall diameter than the front tire. The 295/30-18 is 25.0" OD. The 275/35-18 is 25.6". So your car has indeed got the wrong size (overall diameter) tire on it. The vibration that you are feeling is the AH trying to take control because the rear tires are spinning from it's point of view.
A 295/35-18 rear tire has an overall diameter of 26.1" so it would eliminate tha AH/TC issue.
Not having much time to digest the whole situation but it appears that the car has the same size rims on front and back but different tire sizes. (verify rim width also) If your tire size description is as stated in the OP, rotate the tires front to back same side and see if the problem goes away. A true Z06 set-up has 18 x 10.5 rims on the back and 17 x 9.5 rims on the front. It could be that the original owner bought Z06 look alike rims and then used tire size to get the correct offset. Then at some point in time, the tires were put in the wrong position. (want larger diameter in the rear) Just a thought......
Old Jan 26, 2012 | 09:21 PM
Mrleeks's Avatar
Mrleeks
Cruising
The AH is active almost all the time according to the DIC. I can't confirm the car tire size until the morning because I need to go pick up the car from the shop in Stockton. I am going to try again with the AH off. Also I will take it by a tire shop and have them look at the tires. Any idea about tire shops in the Manteca area? One thing I notice that look fishy is the tire height for the front tire is a 35 while the back is a 30. I didn't think I will be able to rotate the tires because of how wide the back tires are. The back tire is a 295 and the front is a 275. Let me know if you have any other suggestions.
Old Jan 26, 2012 | 10:23 PM
Mrleeks's Avatar
Mrleeks
Cruising
Can you change the tire size in the system AH system? If I went to a tire that was about a inch taller in the rear will it fix this issue. Why are the front tires taller then the rear tires?
C5 Corvette wheels Cast Aluminum
Front: 17 x 8.5 Tire size: P245/45ZR-17
Rear: 18 x 9.5 Tire size: P275/40ZR-18
Bolt pattern 5x4.75" (same as 5x120.65mm)
Front offset=58mm, Rear offset=65mm
Old Jan 27, 2012 | 12:12 AM
m6 c5's Avatar
m6 c5
I didnt think it was possible to change the software written for AH/TC, I was thinking you always had to have a taller tire in the rear? Correct me if Im wrong please
Old Jan 27, 2012 | 07:01 AM
dgrant3830's Avatar
dgrant3830
I was thinking that you can change the tire sizes in there but I'm not positive. If not, then the OP is stuck with 17's and 18's, F and R...at least its that way for mine. The AH is looking at the wheel speed sensors and measuring the spin frequency as such. The AH expects certain spin results for the front vs the rear and when someone deliberately changes things as far as the wheel diameters, there's going to be problems.
Old Jan 27, 2012 | 07:46 AM
SoDiezl350's Avatar
SoDiezl350
This is correct. The AH cannot be reprogrammed to be compatible with tire sizes that are identical.
For the tires specified by the OP, the front tire is 2.4% larger than the rear tire.
The OEM tires, which are 265/40/17 and 295/35/18, the rear tire is 3.0% larger than the front.
Generally, a 2.4% difference should be big enough to keep the computer happy, but I'm not sure how it feels when the bias is shifted from the back to the front. My guess would be that based on the fact the AH is constantly on, that this is the cause of the problem.
My suggestion is to turn of AH and see if it persists. If it does, than you know that it is most likely the tire size that is causing this issue. If the rear tire is changed to 295/35/18, the diameter difference will now shift to the rear tire being 2.4% larger than the front, which should be large enough to allow active handling to operate correctly.
Old Jan 27, 2012 | 09:27 AM
Oldvetter's Avatar
Oldvetter
Looks like the Dealer was right ! You must have a minimum size difference (with rear being taller) for Traction Control and AH to function properly.
Good catch 8VETTE7 !
Mrleeks, you won't believe the performance of your car once you get this fixed. I suspect the TC is "holding" the throttle back during your acceleration because it thinks your tires are spinning !
Old Jan 27, 2012 | 09:54 AM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
I'm thinking these might be aftermarket Z06 replica wheels. Many of these were made in made in China and are pure junk. If they're garbage wheels, this could be the problem.
Take the wheels off and see what it says on the inner barrel. Should be some markings if they're Speedlines or Alcoas.
Regardless, you do need the proper tire stagger or you'll have computer issues.
Old Jan 30, 2012 | 04:41 PM
Mrleeks's Avatar
Mrleeks
Cruising
I turn off the AH and it fix the issue.
Wheels/Tires Stock Specs
Corvette
Front P245/45ZR-17 = 25.68
Rear: P275/40ZR-18 = 26.66
Z06
Front P265/40ZR-17 = 25.34
Rear P295/35ZR-18= 26.12
Here is my tire size and diameter of the tire with the wheels on my car.
Back 295/30/zr18 = 24.96
Front 275/35zr18= 25.57
This is what I think I am going to change to.
Front: 255/30zr18=24.02
Back: 295/30zr18=24.96
This will give it 3.9% difference from the front to back or I can go to
Front: 265/30zr18 24.25
This will give me a difference of 3% from front to back. which do you guys believe will work best?
To Help 2002 Corvette
Old Jan 30, 2012 | 05:08 PM
ALLEGRO's Avatar
ALLEGRO
If at all possible, contact the previous owner and ask the important questions. This could NOT be a new problem, rather one that has been going on for a while and not likely to be noticed in most test-drives.
If it is tires, it can be fixed. Even if it is the wheels, there are many lesser-expensive options to get her back to normal.
Be calm, you and us here on the Forum can get you through.
Good Luck
Old Jan 30, 2012 | 05:30 PM
VETJAZZ's Avatar
VETJAZZ
Old Jan 30, 2012 | 08:37 PM
Mrleeks's Avatar
Mrleeks
Cruising
yes larger diameter on the rear.
