Corbeau A4 owners....
Old Jan 25, 2012 | 04:08 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Corbeau A4 owners....
So I called Mike from TPM and he was VERY helpful, but I didnt want to waste his time since I really did not understand.
I was told that if you attempt to use the stock power seat rails with the Corbeau A4's you will sit too high.... I said okay... What if you get the 'shaved seat' option, which is supposed to give you an extra inch of clearance. Mike said it still will not work.....
Can someone explain why?
Has ANYONE used the stock rails on A4's and made it work?
If so.. What kind of labor is involved?
I dont understand why someone does not make a plug and play seat rail that the A4 can bolt too. The Corbeau rails are 100/ side... .I would easily pay 200/ side to have them use the factory rails.
Old Jan 25, 2012 | 09:29 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I sat in a C5 vert that had the A4's mounted on the stock rails. It is a good thing his car was a convertible because my head stuck well above there the top would be. I'm only 5'11 too. I was staring straight at the sun visor when sitting in the car.
I don't know how he mounted the seats to the stock rails. Custom fab parts I'm sure. He was shorter than me and it seemed to work ok for him, but he still had to remove the sun visor to see out the front windshield.
I like the Corbeau manual rails. No rocking seat issues, and no motors/electronics to break in the future. I'm the only one that drives my car so my seat never moves.
Don't forget that the pass seat mounts in the drivers position.... and vise versa... Seat recline lever goes to the "inside" of the car on both sides. Its because the recline lever on the seats will hit the seat belt re-tractor in the C5's at the base.
Toque
Old Jan 25, 2012 | 09:37 AM
pluslt's Avatar
pluslt
I imagine someone out there could design something for you if you just have to have it. As they say, nothing is impossible, it just costs more $$$. But I gotta agree with Mark here. What's the need for the seat to move unless you aren't the only one driving it? Other than the easy entry feature (which really isn't necessary at all) do you ever move your seat? I don't in any of my vehicles.
Good luck with your search.
Old Jan 25, 2012 | 09:40 AM
ICULUKN-C5's Avatar
ICULUKN-C5
I forgot that the new rails will fix my rocking seat... Good point.... score one for the manual adjustment. I just thought with the extra bolster that maybe it would harder to get out of the car.
Old Jan 25, 2012 | 12:52 PM
7LitreC5's Avatar
7LitreC5
The problem is that with the stock seats the power mechanism is mounted in the seat cushion. The bottom seat cushion on the stock seat is hollow and part of the power mechanism protrudes into that space. With the A4s the bottom is flat so you would have to space the seat up to clear the power mechanism.
blackdak318's Avatar
blackdak318
Just installed a set in my C5Z about 2 weeks ago. I agree that mounting them to the stock rails would seat you way high. I have them on the corbeau rails and I could tell I was sitting slightly higher.
I would definitely recommend just biting the bullet and getting the corbeau rails. I think after all is said and done you would have a lot of time and money into making the stock rails work and you probably wouldn't be that happy with the seating position.
Old Jan 25, 2012 | 06:20 PM
silverbird's Avatar
silverbird
St. Jude Donor '08
"I have them on the corbeau rails and I could tell I was sitting slightly higher."
Did you use the Corbeau shaved version rails?
Silverbird
Old Jan 25, 2012 | 06:46 PM
7LitreC5's Avatar
7LitreC5
There is no difference in the rails. Mike at TPS told me that the 1" lower version has the bottom cushion shaved 1".
Silverbird
Old Jan 25, 2012 | 06:49 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
I have a brand new set of A4 rails I would like to sell....single adjustment. At one time I was going to put some A4s in my car. $185 plus shipping.
Old Jan 25, 2012 | 07:34 PM
MrMojoRisin921's Avatar
MrMojoRisin921
The Corbeau rails work fine, though I wish they were made of a lighter metal for more weight savings.
Old Jan 25, 2012 | 08:48 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Toque
Is the reason soley because of the seat belt retractor? Just curious if you could fix that, if you could actually mount them as they are designed with the recliner lever on the right. Thanks.
Old Jan 25, 2012 | 08:59 PM
Toque's Avatar
Toque
I think if you shaved/cut the plastic around the seat belt re-tractor you may be able to get it to work. It would likely look bad though maybe. I dunno.. Its really not a big deal having it on the inside though. I think I adjusted mine once in the last year to try a different recline angle...
Toque
Old Jan 26, 2012 | 04:05 AM
jd86L98's Avatar
jd86L98
I have the shaved option and Corbeau rails, I actually think I am about the same as stock. Love my A4's and have not missed my power seats.
Old Jan 26, 2012 | 01:06 PM
TXGS507's Avatar
TXGS507
Unless your buddy gets into your car and starts jacking with the adjustments..
I like the Corbeau manual rails. No rocking seat issues, and no motors/electronics to break in the future. I'm the only one that drives my car so my seat never moves. Don't forget that the pass seat mounts in the drivers position.... and vise versa... Seat recline lever goes to the "inside" of the car on both sides. Its because the recline lever on the seats will hit the seat belt re-tractor in the C5's at the base.
Toque
Old Jan 26, 2012 | 02:22 PM
Toque's Avatar
Toque
You like to sit "layed back" for sure. I could not even reach my pedals after you adjusted it... I fixed it though...
Toque
Old Jan 26, 2012 | 02:30 PM
onspeed's Avatar
onspeed
is there height adjustment with the corbeau?
Old Jan 26, 2012 | 02:32 PM
Toque's Avatar
Toque
Just add some washers under the seat, or at the mounting base. I added about 5/8" of lift to the front of the seat. Feels just right for me.
Toque
To Corbeau A4 owners....
