Build sheet location?
Old Jan 29, 2012 | 08:47 AM
David Shiel's Avatar
David Shiel
Default Build sheet location?
I have a repro build sheet from the museum, but wonder if the plant attaches a sheet to the car and , if so where would I be likely to find it?
Old Jan 29, 2012 | 08:52 AM
CHJ In Virginia's Avatar
CHJ In Virginia
Factory build sheets for C5 Vettes are stuffed into the front frame crossmember on the drivers side. They are a PITA to get out because you have to remove the front fascia to access the open end of the crossmember. Mine was in bad shape when removed - water damage.
Old Jan 29, 2012 | 08:54 AM
RamAirTA's Avatar
RamAirTA
From: I'll Keep My Guns , Freedom And Money. You Keep The Change. FL
I believe I heard it was inside the front bumper support. I come across this info a few weeks ago but have not verified it. Anyone have the front bumper cover off their car?
Old Jan 29, 2012 | 09:02 AM
That's where it should be - I pulled my build sheet out when I had a little repair done to my front fascia about two years ago -was still in very good shape and now have it framed and hanging on the garage wall.
Old Jan 29, 2012 | 09:29 AM
David Shiel
Default Thanks so much
for the replies. I think I'll let it rest in peace. If ever I need to access that area, I'll go after it. Used to be many manufacturers put the sheets under the carpet or under a seat, usually the rear seat in sedans.
Thanks,
Dave
To Build sheet location?
