School Me on Headers
In terms of brands, what is the primary difference between Kooks, LG, XS Power, SLP and others? Also, what is the performance difference or deciding factor when it comes to 1 3/4" vs. 1 7/8" headers and is what is "coating"?
Cats are required for street driving and the "No Cat" option is for track use correct? (Or in theory?!)
Also, what is the difference between a 3" X 3" vs. a 3" X 2.5" X-pipe or cross over pipe option?
Lastly, how much HP can you expect on a stock C5 LS1 with an A4 and is it worth it if you stop with new headers, new cold air intake and a tune?
Thanks!
P.S. - I was going to post this in the Tech section, however I thought I would get a better response in General.
As far as 1 3/4 or 1 7/8, you will have to provide some more information. Are you ever going to go with a bigger motor? Are you planning on a S/C?
1 3/4 is most common, thats what I have with 600hp, but some big HP guys go with 1 7/8.
First I need to complete my little paint project we discussed. I have the Caravaggio spoiler and other components sitting in my garage while I'm waiting for the painter/bodyshop to get me on his calendar.
After that, I plan to get some new wheels (CCW 505As) and install some new shocks when I have the wheels off and the car up on jack stands.
Then, hopefully around summer or fall, I plan to start upping the HP with a new cold air intake, headers/tubes, a thermal tunnel plate and a tune. I am not planning for a SC or Maggie, just some added bolt-on performance.
Thanks for the explanation on the ceramic coating. I saw some pictures of some very nice, polished coating that looks really good. Did you go with a particular color or just a polished coating?
The stock manifolds on these are fine. They aren't like they were years ago.
But if you are going to spend the money, then I agree with what blitzkrieg said.
Oh one more thing, if that's all you're going to do and not really build your engine with a cam etc, then I wouldn't spend the money myself. But I know I'm in the minority on that one.
There is a common misconception that larger primary sizes flow better because they allow more air to pass through. This is not completely accurate. Yes, a primary that was too small would be restrictive, but a larger primary causes air to flow too slowly creating a higher pressure...pressure that restricts exhaust flow.
Remember back in physics class we learned about the bernoulli effect. The smaller the pipe, the faster a fluid would flow through it and at a lower pressure.
This same idea applies to the rest of your exhaust as well. For stock cube N/A cars, 1 -3/4" primaries are plenty. Similarly, a full 2.5" exhaust system is usually enough for a similar setup and it fits nicely inside the factory tunnel. Some 3" systems will hang a little lower than the 2.5" versions.
With headers, there is a "magic size" of pipe that provides enough of an opening to not be restrictive, but keeps exhaust gases moving quickly so there is the lowest possible pressure in the primary. The lower the pressure, the less resistance force the piston encounters on the exhaust stroke. In the optimal header setup, a piston might even see a vacuum on part of the exhaust stroke which pulls the piston upwards.
Since exhaust is not a consistent flow but rather a series of pulses, each pulse has a low pressure wave behind it. The design of headers with equal (or close to equal length primaries) is to a) match the distance each pulse flows to meet the collector and b) match the direction of exhaust flow in the collector. The factory exhaust manifolds to an incredibly crappy job at this by shoving all the exhaust into a single log-style manifold and (in some applications) cramming the front and rear cylinders together.
When an exhaust pulse hits the collector the negative pressure is felt by the remaining 3 primary tubes and effectively pulls other exhaust pulses along. Primary length determines the "Sweet spot" where the exhaust pulses harmonize in reaching the collector so their pulses reinforce this effect. The shorter the primary, the less time a pulse remains in the primary before it hits the collector and thus the sweet spot is in effect only at higher RPMs when the pulses are closer together. Similarly, mid-length headers have sweet spots in the mid-range of the power band and Long tube headers have the greatest effect felt lower in the power band.
It's worth noting that LG's Super pro headers with their 42" primaries are so long that they have 2 sweet spots: one where there is one pulse per primary and another (at a higher rpm) when there are 2 pulses per primary. One can hear the harmonics when the engine revs around 2000 and 4000 rpm.
A good exhaust and intake system with a good tune can net anywhere between 15 and 40hp, but the biggest difference will be torque. You will defiantly be able to feel more power when you put your foot into it.
Also if Im not mistaken Lg's headers have 32 inch long primaries but I could be wrong.
If you don't get them coated, ALL systems will tarnish and turn blue/brown, even if they're stainless. So, if you have a low mileage garage queen, and you're into car shows and such, I would definitely recommend getting them coated. Definitely go with high flow cats. There are really no benefits to going catless, and you will have unpleasant smells. Go with 1 3/4" primaries unless you are planning on going FI in the future.
After I installed the headers, I had the car tuned by ECS. It made a very noticeable seat of the pants difference.
