in order to make these wheels fit WITHOUT any modification, is to run this narrow tire 295 on a 12'' wheel...
Oh no I understand that. The problem is you bought the wrong size/offset wheel to fit the stock fenders with the correct tires on.
I have a buddy that did even worse on his honda hatch. He streched the tires AND put them at like 10 degrees camber to clear the fenders. So he got wider rims, but only rides on the inside couple inches of the tire. I can slide a piece of paper nearly halfway under his tires. Definetly not a performance upgrade. I rib him here and there about it, but all in good fun. He enjoys his car, all that matters
Chassed -- I was just speaking to Dan at CCW about a similar set up and set of wheels but he mentioned back spacing "concerns" from the fist set (MY Z06) and possible "rubbing" on the leaf spring. Have you had any of these issues? Just wondering if you're on coilovers or stock spring and lowering bolts? TIA
I'm lowered max on an aftermarket bolt in the rear, and front bolt removed, stock Suspention.
Ive had ZERO issues.
^^^youd be surprised how many people have been hating on the look I've got going.
I know a lot of people have Classics, but I wanted mine to stand out a bit.
Thanks for the comments :-)
