LS6 Manifold parts
Old Feb 3, 2012 | 11:00 AM
bontrager's Avatar
bontrager
Default LS6 Manifold parts
It's my understanding that I need the following parts to complete the ls6 manifold install on my 2000 vert:
Corvette OE Cooling System Air Blead Pipe Assembly, includes O Ring Seals and rear coolant plugs (2 each).
Where can these be purchased? Mid America motor works have these on back order for some time now.
Please help, thank you
Old Feb 4, 2012 | 09:14 AM
Radicaltimes's Avatar
Radicaltimes
You might want to look in the stickies. You can mark and cut off some of the ridges on the bottom side of the intake.This way should not have to replace to the newer style cross over pipe. When ever I get a LS6 intake this is what I will do.
Old Feb 4, 2012 | 08:42 PM
corv1998's Avatar
corv1998
When i installed my ls6 manifold on my 98 , i just ground off the small webs on bottom of manifold. It is so much easier then changing the coolent path . A small disc grinder or dremmel tool , or even a drill motor with a small fill bit will do it with ease , no worry just remove them all ,not a problem with the strength of manifold .
To LS6 Manifold parts
