18s wheels all around
Old Feb 4, 2012 | 08:08 AM
Ekul61's Avatar
Ekul61
Default 18s wheels all around
Just purchased a o3 and didn't realize it has 18" wheels all around. Why would a person change to the 18s?
Old Feb 4, 2012 | 09:48 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Probably because the previous owner was stupid and didn't know any better. Also possible is that he/she thought maybe someone else messed up and put on the wrong ones then it started having AH/TC system issues, so they dumped the car.
Old Feb 4, 2012 | 10:21 AM
charger21's Avatar
charger21
C5 of Year Finalist (track prepared) 2019
I run 18's all the way around without TC issues. Who is stupid now?
Old Feb 4, 2012 | 10:24 AM
Ekul61's Avatar
Ekul61
I guess the guy 2 up thinks 18s will hurt the performance.
Old Feb 4, 2012 | 10:37 AM
meflyfrc's Avatar
meflyfrc
I am running 18 all around will no AH/TC issues. Typical combinations for these cars are 18/18, 19/19, and 19/20.
Old Feb 4, 2012 | 10:42 AM
BACNBLK's Avatar
BACNBLK
I dumped the stock sizes and went 18/19's, definitely like the look much better and filled in the wheel wells much nicer!
Old Feb 4, 2012 | 10:58 AM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
you can easily go 18/18 or 19/19 and have no issues as long as you get correct tires for the car
as mentioned you still have to watch the diameter of the tires
19/19 for me and not an issue at all with AH/TC
265 30 19
305 30 19
Old Feb 4, 2012 | 11:00 AM
Darion's Avatar
Darion
Stupid huh, must be more than a few stupid people runnin 18's all around on this board.
You must be one of the stupid ones!
I am running 18/19 combo but due to tire size options kinda wish I had done 18/18 combo. Wasn't really an issue before the SC system but is now. Could get a wider rear tire with a but more sidewall in a better tire for traction then I have found in 19's.
I may just be getting more stupid in my near future.
Darion
Old Feb 4, 2012 | 11:17 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I run 18 inch wheels on all 4 corners and never had an issue, I like the look of 18 all around.
Old Feb 4, 2012 | 11:24 AM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
I also run 18s all around. It's not the diameter of the wheel that matters so much. It's the tire selection.
Old Feb 4, 2012 | 11:30 AM
xceleratevette's Avatar
xceleratevette
those of you running 18 i just picked up some z06 18*10.5 and 18*9.5 what would you suggest for tire size i do have active handling thank you chris
Old Feb 4, 2012 | 11:52 AM
tiojames's Avatar
tiojames
Another one who posts w/o any knowledge. I have ran 18s all around for over 6 years with no problems at all. It has to do with tire diameter, not wheel diameter.
Old Feb 4, 2012 | 11:54 AM
tiojames's Avatar
tiojames
Check the diameters of the tires you want-the front should be 1/2" less than the rear to keep the active handling happy.
Old Feb 4, 2012 | 12:22 PM
MSG C5's Avatar
MSG C5
Damn Dennis! Great picture!
Old Feb 4, 2012 | 12:23 PM
Edmond's Avatar
Edmond
And he's a tech contributor?
Old Feb 4, 2012 | 12:30 PM
Darion's Avatar
Darion
No kiddin!
Darion
Old Feb 4, 2012 | 02:10 PM
dgrant3830's Avatar
dgrant3830
Ok guys, please allow me to retract my less than professional comment. Some people have managed to do this without issues. My comment was related to the AH/TC problems that can and do result with the tire diameters not proper in respect to the PCM/TC system programming. I apologize if I offended anyone.
To 18s wheels all around
Old Feb 4, 2012 | 02:17 PM
charger21's Avatar
charger21
You're good buddy!
Old Feb 4, 2012 | 02:18 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
been running 18's all around for years....no issues....
am I wasn't offended
Old Feb 4, 2012 | 04:40 PM
PMPNSEZ's Avatar
PMPNSEZ
Maybe the OP got lucky and bought a C5 with a big brake kit on the front which would require the use of an 18 wheel. That would be my first question
