Can I get your take on the intervals you do the following services for your C5? Also, if you have a preference for a certain product or any other info please share. Thanks! Jax
Air Filter
Fuel Filter
Transmission Fluid
Belts
Coolant
Gear Oil
Battery serviced/charged
This is what I do on my C5 DD, but I am only at 50k miles after 11+ years - all in town driving...
Air Filter
I have an oiled Hurricane filter - clean and re-oil once per year (twice a year would be smarter)
Fuel Filter
Changed mine at 40,000 miles
Transmission Fluid
Changed fluid and filter at 40,000 miles
Belts
Changed at 30,000 miles
Coolant
Flush and change every 3 years
Gear Oil
Engine Oil/Filter
Every 6 months (overkill)
Drive everyday, so no need to charge, but I replace Red Tops every 3 years just to be on the safe side - however with Red Tops it is like rolling the dice.
Its a valid question because if you go by the manual you replace the plugs at 100K miles and everyone here says that they are too worn long before that.
I've only got 15K miles on my '03, but here is what I've done so far. Just did the maintenance so I would know that things were great right after I bought the car. In addition to the ones you have listed, I changed the brake fluid at 10K miles.
Originally Posted by JaxEagle
Air Filter - Have a Blackwing on the car - so far, no need for any cleaning.
Fuel Filter - changed it @ 10K miles.
Transmission Fluid - changed it at 10K miles
Belts - still on the original ones.
Coolant - changed it at 10K miles.
Gear Oil - previous owner had the leaking differential seal - oil was changed under warranty with about 4K miles on the car.
Battery serviced/charged - Replaced the Red Top that was in the car when I bought it in October 2010 - Red Top bit the dust. Now have a Sears DieHard Platinum in the car.
