Installed Heated Seats
I got heated seats and wanted to share my install with others who are considering this mod. There is a lot of threads about this topic. So here you go....If you are removing the seats for the first time then use the Vette Essentials instructions. I also used 3M connectors as you can see from the pics below to tap for power. You can buy them from Grainger. I couldnt find them in Homedepot, Autozone, etc at least the ones in my area.
I got the heated seats as a X-mas gift from Mid America, they have Lo, Mid and Hi. So first thing I took the seats out and the console, as shown below
.I decided to install the buttons by the traction control button. So I marked the buttons from the inside and then used a gradual drill bit. Trial and error till i got a good fit. Below are few pics
I used a thin blade saw to make a groove so the wires can come out from the sides. I basically cut a 1/4inch downwards and a width of the wires diameter side by side. Below is a pic of how the wires come out.
I run the ground wires to the screw underneath the glove box as shown below (Closeup look)
I got the power by tapping into the yellow wire inside the access panel underneath the glove box on the passenger side, as shown below
Below is a pic with one seat in place to make sure everything is working (And it was)
Below pic everything is back with the exception of the passenger seat.
This weekend I want to redo the placement of the bottom heated pads, so I get the heat in the right place, should take 30min per seat. I take my time
Hope the pics help newbies or someone planning to do this mod. Take your time, I used alot of zipties so have the wiring very well tucked.
RB
We offer the Metra heated seat kits as well
1 piece for the back and 1 piece for the seated area
illuminated 3-position switch
material can be trimmed
heating element and pad are carbon fiber
dimensions: 18 x 9
power rating: dc 12v 25 +/-3 watts x 2
59.99 shipped per seat
CLICK HERE FOR ORDER INFO
Will be doing this when I get around to putting new seat covers/pads in
http://www.mamotorworks.com/corvette...seat%20heaters
i had not seen the 3 stage aftermarket heaters and this is what i want to do for my wifes e320.
The one I have is a 3 position as well.
The ones I have linked(have 2 other options)
have the same switches as Ramez
We are actually putting a set in a custom set of leather race seats now
The switches will be at the top of his custom DD radio bezel along with 2 gauges in between them
oh
and the bezel will also be finished in leather with yellow stitching
Darn good post, it's appreciated.
