Its in the Paint
Old Feb 11, 2012 | 02:40 PM
Manny De Leon's Avatar
Manny De Leon
Default Its in the Paint
Ok, I was washing the car today and I noticed this discoloration or something. I took to with my buffer and cleaners and it seems to be in the paint. This is the area behind the driver head rest. I am not sure what it is. I am not all that concerned yet, since it doesn't stand out---yet. Anyone ever seen this before.
my car is a 2001 MY Vert.
Old Feb 11, 2012 | 02:45 PM
Have not seen something like that before. Might want to check with a good body shop and see what they say.
Old Feb 11, 2012 | 02:58 PM
dougbfresh's Avatar
dougbfresh
Looks like it's under the clear, has that panel ever beed repainted?
Old Feb 11, 2012 | 03:11 PM
TorchRedRocket's Avatar
TorchRedRocket
Maybe from the seatback and headrest rubbing? Do you have your seat all the way back?
Old Feb 11, 2012 | 05:47 PM
540 vette's Avatar
540 vette
Did you ever notice this before. That would not just appear under the clear for no reason. It looks like the headrest rubbed up against it. If you look at the picture it looks like when you sand orange peel. Try some 2500 wet and dry paper then buff.
Old Feb 11, 2012 | 07:22 PM
ALLEGRO's Avatar
ALLEGRO
Ten-Foot rule if you ask me. Might be better to accept it "as is" than to try to fix it and it come out even worse.
Good Luck
Old Feb 11, 2012 | 08:20 PM
sfc rick's Avatar
sfc rick
GM had a problem with the bonding agent used in production around the 98-00's, I say this because my Firebird had a panel start to appear discolored and eventually seperate the clear coat from the paint base coat following the same path as the adhesive was applied on the rook panel.
It was over 6 years from the date of production but the GM dealership made a call to the regional reps and they warranteed the work and paint job. They explained the reason that the adhesive had been causing them some issues so they changed the formula.
I don't know where exactly your paint trouble is located or even if it's old adhesive related. Just an FYI.
To Its in the Paint
