But a lot of members have DIYed air intakes out of the stock front plate cover. I foresee no reason why you shouldn't be able to duplicate that process for the plate "vs" the grille.
The one from the factory is the U shaped piece - nothing on the top of the plate. I too have seen members take a clear cover (shaped just like the factory one if you don't have to run a plate) and paint it on four sides with the center open to show the plate. Doesn't look too bad.
Thx, just found out that you buy a clear cover and paint it.
I did this and it turned out great but after a few months, moisture collects inside of the plastic and it began to fade and tarnish. I ended up removing it and going with the 3 sided version.
Only painted the outer boarder of the clear cover from the inside. As I stated earlier, it turned out great until the condensation took its toll on the plastic.
I have the clear cover on mine, haven't painted it.
Maryland has a law against covering the plate also, but it is not enforced much as long as you don't use a dark tinted one.
I've looked at this 'problem' for years and IMO its just a necessary evil car owners have to deal with. I have the 'regular' u-shaped one, and it's a K-I-S-S solution to a requirement here in NJ.
