I have been reading about Dexron 75/90 LS gear oil for Corvettes. My question is, Is This oil synthetic ? and is it recommended for C5s or just C6s. I am going to change the differential oil in my C5 and was a bit confused about the recommendations. I have no problems with my differential. Its just time to service it.
Thanks.
There was a post recently by a member that changed the Dexron LS and it lead to a probably lowering in performance of his limited slip diff (less limited slip). I suspect the Dexron LS has too much additive for the C5 diff.
I use and recommend this without extra additive as it has additive already in it but at low enough levels to prevent diff chatter without inhibiting performance of the diff: AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT)
