I would like to know if anyone has used the adams polish to remove fine scratches on their car? and what the resolts where. I have a couple on the hood of my car and would like to remove them if possible, not deep but very fine (before I take it to a detail shop$$$$) thanks. GINO
I use Adams all the time and yes it will remove minor scratches. You can do it by hand if they are not real bad, but I suggest that you get a good random orbital buffer such as a Porta Cable. The clear coat on Corvette's is extremely hard, so you will need to work on them.
I would also suggest that you take a few pictures of the scratches prior to starting to correction and if you are have an issue go the the Adams forum post the pictures and what you are doing and you will get the best help around.
You might need to go with something more agressive than polish, like the swril and haze remover with the orange pad first then follow it with the polish and white pad.
Not heard of Adams, but have used the Meguairs line of products since they were only available to professional painters some 30 years ago. If your car is garage kept, then you can remove some of the scratch, but not all to keep as much clear coat as possible. Then use a glaze (sometimes referred to a Quik Detail. A glaze does not last as long as wax, especially if not garaged. When I bought my 2001 there were some light scratches and all I did was put some pure wax on first then the glaze on them and they disappeared. I reapply every month or so as needed. You can do this by hand if you don't have a buffer. I did mine by hand even though I do all my own show quality painting. Good luck, Sam
I used the Adams products on my 2001. Had some scratches that were deeper than swirl marks. Used the clay bar, swirl and haze remover, revive polish and the buttery wax in that order, all by hand and spending a bit of time with each. I was very pleased with the result. I'm planning on doing this entire treatment once per year, with the occasional polish only and wax in between.
I use a variety of the Adam's polishes on my car - the Scratch Out is a more abrasive product and you have to be careful not to rub too hard with it. I also use their Revive product - it is a milder product and does a good job getting rid of minor surface scratches.
