[Z06] LS7 clutch - possible problem?
Old Feb 15, 2012 | 01:59 PM
The Evil Genius's Avatar
The Evil Genius
From: Dayton, OH HAWG: "this is Off Topic...it can get a bit north of care bears and strawberry shortcake in here"
Default LS7 clutch - possible problem?
I installed an LS7 clutch in my Z06 recently. It works really well, if a little low on the engagement point (close to the floor). 1-6 work perfectly fine, but occasionally reverse grinds just slightly and the car bucks. Once there's that small grind and clunk, it goes into gear and is just fine. I can let off the brakes, and the car doesn't move until I let out the clutch.
So do I have a clutch issue (do I need an adjustable master? I have stock C5 hydraulics) or a trans issue?
Thoughts?
Will
