Are the new corners hard to install. I'm not a super mechanic like some of you guys on here
Not hard. If you're only changing the corners, go in from underneath the car. If you're performing and HID swap with the headlights, go in from the top since you will have the headlights out.
Looks really good, but I am not sure that is DOT legal. My 2 cents.
When I switched to LED's I ordered amber but got whites so I just used them and kinda liked the look. So I kept them on. Been on for 3+ years now and so far no problems with 5-0. Of course I probably jinxed myself now.
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
use JW's info from above...
it's ez...7 mm wrench will do the small screws that need to come out...i think it was 3 at each side...be careful not to scratch the new clear lenses when putting them in...it's a tight squeeze, but anyone can do it....easier to do it from above, but i did it the hard way with my 4 post lift....the ramps were always in my way.
Are non amber signals legal or is that a state to state thing?
I think the same law covers all 50 states, however I know the Florida statute indicates that the front corner reflector has to be amber and the rear corner reflector has to be red. I believe switchbacks are DOT compliant because the turning portion switches to amber.
Technically though, the Florida state statute reads that any type of modification to factory lighting is illegal.
Black/Clear. They look great with the MSG and I am sure with the Black too. I went with the super bright White LED's, look great as DRL's and flash white when used as blinker's, or you can get the switchback's which are white when DRL but switch to amber when you use your blinkers. I think they look better than stock. JMHO Here are some pics, the first one is a before pic with the stock lights. You be the judge.
love the headlights ,what are they and where can I get them ,they are by far the best to my eye
