Will these wheels stick out?
Old Feb 16, 2012 | 07:28 PM
Levi Walker's Avatar
Levi Walker
Default Will these wheels stick out?
Will they stick out?
Would these need a spacer or tub?
What size tire in the rear, 325?
http://www.ebay.com/itm/18X9-5-19X11...item2c56a9d056
Old Feb 16, 2012 | 07:32 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Why not ask the seller?
Old Feb 16, 2012 | 08:13 PM
I don't think you'll have any problems with the fronts but the seller doesn't list the offset on the rears. Here's the specs for the stock wheels -
C5 coupe/convertible:
Front 17x8.5", +58mm offset = 7.03" backspace
Rear 18x9.5", +65mm offset = 7.81" backspace
C5/Z06:
Front 17x9.5", +54mm offset = 7.38" backspace
Rear 18x10.5", +58mm offset = 8.03" backspace
If the rears are close to the specs above, they should fit.
Old Feb 17, 2012 | 02:08 AM
jdmvette's Avatar
jdmvette
Night Owl for life
the 19x11 needs to have a +63 to +65mm offset for a perfect c5 fit.
a higher offset will rub on the inside and a lower offset will stick out.
go with a 305/30/19 for a perfect fit.
Old Feb 17, 2012 | 10:46 AM
Levi Walker
Oh wow, I can only get a 305 fitting perfect?
Old Feb 17, 2012 | 11:05 AM
jdmvette's Avatar
jdmvette
Night Owl for life
a 325 needs a 12" wheel and a 12" wheel will stick out.
Old Feb 17, 2012 | 11:35 AM
Levi Walker
Ok cool, thanks!
Old Feb 17, 2012 | 02:07 PM
ZZ4Vetteguy's Avatar
ZZ4Vetteguy
St. Jude Donor '08-'09
I run 19x11's on my 01 Vert and run a 325/30 19 with no issues what so ever.
Old Feb 17, 2012 | 02:29 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Most tire manufacturers will state a rim width range of between 11" to 13" as acceptable for a 325x30x19 tire. the optimum rim width is usually stated as between 11.5" and 12". So it will depend somewhat on the individual brand of tire. But others here actually running that size wheel and tire will provide the most input.
To Will these wheels stick out?
