which brake fluid with ss lines
Upgraded lines? They just have a woven stainless outer shield instead of rubber over the inner tubing. Stronger yes, but no other difference.
Which ever one you go with purge the lines get all the old out of her... RobertUpgraded lines? They just have a woven stainless outer shield instead of rubber over the inner tubing. Stronger yes, but no other difference.
Also, I'm pretty sure DOT 3 will eat the paint as well as DOT 4.
Motul 600 is what I use.
then you have to replace all components and lines...
I've seen people do solvent flushes, alcohol flushes, etc... it isn't worth the headaches, unless you are already replacing the entire system
http://forums.corvetteforum.com/c5-g...ll-w-pics.html
Thanks,Matt
DOT 5 is silicone-based fluid and should not be used in any system that use anti-lock brakes, or have not been completely flushed of 3/4/5.1 fluids. Even then you run the risk of ruining seals.
Nifty boiling point chart from wikipedia.
DOT 3 205 °C (401 °F) 140 °C (284 °F)
DOT 4 230 °C (446 °F) 155 °C (311 °F)
DOT 5 260 °C (500 °F) 180 °C (356 °F)
DOT 5.1 270 °C (518 °F) 190 °C (374 °F)
Last edited by _r2h; Feb 18, 2012 at 10:29 PM. Reason: include nifty boiling point chart
