97 c5 heat problem
Old Feb 25, 2012 | 11:45 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Here are all of the possible HVAC codes the system monitors:
99-HVAC - Heater, Ventilation, Air Conditioning
B0332 Outside Air Temp Sensor Short to GND
B0333 Outside Air Temp Sensor Open
B0337 Inside Air Temp Sensor Short to GND
B0338 Inside Air Temp Sensor Open
B0348 Sunload Temperature Sensor Open
B0361 Left Actuator Feedback Short to GND
B0363 Left Actuator Feedback Open
B0365 Right Actuator Feedback Short to GND
B0367 Right Actuator Feedback Open
B0441 Left Actuator Out of Range
B0446 Right Actuator Out of Range
B1016 Loss of Communications with PCM
U1064 Loss of Communications with BCM
U1096 Loss of Communications with IPC
U1255 Serial Data Line Malfunction
Old Feb 26, 2012 | 02:26 PM
IRON MAIDEN's Avatar
IRON MAIDEN
Well, I don't see one that tells you that you just need to recharge your refrigerant. Is there a procedure for this? or do you just gamble and pay a shop to recharge it? or is it a DIY job these days?
Old Feb 26, 2012 | 03:56 PM
dmarkshark's Avatar
dmarkshark
Iron Maiden, what system do you have? And, there is no code that tells you that you are low on refrigerant, if that helps.
Old Feb 26, 2012 | 05:29 PM
IRON MAIDEN
It's the basic 1 zone setup from the first model 97'.
If there's no code for it, what is the procedure for checking and recharging the system? Can it be done DIY style or is it require special equipment???
Old Feb 26, 2012 | 11:23 PM
dgrant3830's Avatar
dgrant3830
For R134 systems, the amount of refrigerant is based on system capacity and environmental temperature at the time of filling. The proper way is using special equipment to evacuate and recharge it. Some get away with adding a can to it but you might over-charge it too. I'm not a specialist in this but in my case, I default to a professional shop when needed.
Old Jan 16, 2013 | 09:02 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
So, did you guys get this problem taken care of? I put off adding refrigerant last fall...I was looking at adding it now that it is in storage, but the temp gage on the 134 kit doesn't go to these colder outside temps. Does that mean I can only add 134 in hot weather?
Old Jan 16, 2013 | 09:39 PM
RMB97LS1's Avatar
RMB97LS1
Is the original issue a temp or fan issue? My 97 temp works, but there is no fan on the drivers side. Pass works well.
Good remedies listed here and I'm going to try all of them.
