[Z06] NCM - Corvette Store
Old Feb 20, 2012 | 03:24 PM
NCM Store's Avatar
0NCM Store
Former Vendor
Default NCM - Corvette Store
National Corvette Museum Store
C5 Corvette Emblem Travel Chair
(Click Image to see item on the website)
Easy Rider Travel Chair made with two layers of strong 600 denier polyester. Features high quality steel tubing, seat belt webbing reinforcements throughout, armrests with mesh drink holder, the C5 Corvette emblem screened on the back of the chair and a matching stuff sack. 20.5"W x 31"H x 21" D. Tested capacity of 1000 lbs.
$55.00
C5 Corvette Nailshead Shirt
Men's Easy Care Nailshead shirt features a button-down collar, a front placket, a double back pleat, a chest patch pocket, barrel cuffs and the C5 Corvette emblem embroidered on the left front chest. 60% cotton, 40% polyester.
$68.00
C5 Corvette Illuminated Windrestrictor
The C5 Corvette Windrestrictor is in a class of its own. It's the first deflector in the world that can remain in place while your top goes up and down. Top quality powder-coated steel bracket system. No drilling or modification. Truly unique.
Benefits include:
•Significantly reduces rear wind turbulence inside your roadster
•Maintains cabin temperature while driving with the top down
•Enjoy conversation without raising your voices
•Better sound clarity from stereo with reduced wind turbulence
•Personalizes and sets your Corvette apart from the rest
•Additional rear light for added safety on the road
•Passengers can talk more clearly on cell phones
A complete installation guide and step-by-step video will come with your order. The Windrestrictor hooks up to come on with headlights or taillights. To view an installation overview click here.
Add on Accessories Available:
Extreme Lighting Kit (ELK) - $129.00
The ELK is a brand new upgraded option for the Windrestrictor® It allows the driver to utilize a remote control to choose between multiple colors of illumination for the product at any given time. There are several static, single color options as well as a few different “fading” options and cool effects all from the push of a button. This is the perfect option for car shows! Also, perhaps the best feature of this package is the remote on/off switch where you can turn on or off the unit at any time with the press of a button.
Brake Lamp Module with dimmer ***** - $99.00
This option is a very nice option. It's a module that you can install in your trunk or behind your seat. It has 2 ***** on it. After installed the first **** will control the running light intensity to your product. You can use this **** as a dimmer **** to adjust the illumination while you are driving with your running lights on or headlights on. The other **** controls the brake light intensity to the product. You can adjust this **** if you want the product to illuminate when you apply pressure to your brakes. With this option you can set the product for the following:
•Restrictor can be set to come on only with the head lights
•Restrictor can be set to come on only with the brake lights
•Restrictor can be set to produce a certain illumination while driving (like a mid-intensity) and then produce a brighter glow when you apply pressure to your brakes when you stop. Kind of like a 3rd brake light option.
•Also, this module will allow you to turn off product all together if you want. If you did not want it on for some reason, then you could turn both ***** down and then you'll just have the laser etching. Finally, the new brake light module come with a built in battery pack (9V). So just flip the toggle switch and you can have the restrictor illuminate at the intensity you desire even when the car is off. (good for car shows). So this is a wonderful option that allows you to tap into your running lights and your brake lights simultaneously, and adjust each independently.
$499.00 (special shipping charges apply)
C5 Born In the USA Corvette T-Shirt
American Pride is reflected in this T-shirt featuring the Stars and Stripes and the C5 logo. 100% cotton. Small C5 logo on left front chest.
$16.95
C5 Corvette Ladies' Kingston Pique Polo
Ladies' DryTec™ Kingston Pique polo features a self-fabric collar, a three-button placket, princess seams, side vents, open sleeves and the C5 Corvette emblem embroidered on the left front chest. 100% moisture wicking polyester.
$52.00
Contact us at storecustomercare@corvettemuseum.org
or 800-53-VETTE.
We look forward to hearing from you!
To see more, click here.
