ignition switch
Old Feb 20, 2012 | 07:31 PM
c-low's Avatar
c-low
Default ignition switch
Once u change out a bad swicth in a c5 how do u program the body control module to reconize the new switch and key or do u have to replace both
Old Feb 20, 2012 | 11:41 PM
dlind4's Avatar
dlind4
Did you replace the lock cylinder or the ignition switch? If just the switch then you don't need to do anything. If the lock cylinder then a locksmith can code it for you. The key has a resistor so the locksmith or dealer can order the same key. You don't need to do anything with the bcm.
Old Feb 20, 2012 | 11:46 PM
Choreo's Avatar
Choreo
I replaced my Ignition Switch (the electronic contacts and mechanism) but retained my original key and cylinder - no reprogramming.
To ignition switch
