Oil leak
Old Feb 21, 2012 | 08:56 PM
99alvette's Avatar
99alvette
Default Oil leak
Hey folks my 99 has a small leak comming from either the oil pan or the drain bolt no more than 3 or 4 drops and the car hasn't been started in about 2 months is this normal the car has just under 30k on it.
Old Feb 21, 2012 | 09:18 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
It is common in a sense. I may have one as well, sometimes it seems like there's a couple of drops and others none.
I did some reading on it and found it could be the drain bolt, or the oil level sensor, or possibly the drain pan. Or in some cases a more serious seal.
Until you get it up in the air it's hard to know exactly where it's coming from.
Old Feb 22, 2012 | 12:10 PM
Cirrus8's Avatar
Cirrus8
My car developed a leak that seemed to come from someplace around the front of the oil pan. I determined that it was leaking through the oil pan seal in the area where the drain plug is. I turned all of the pan bolts approx 1/4 turn tighter and the leak is gone. I suspect that the torquing of the drain plug over several oil changes may have caused it. Hopefully, it is gone forever.
Old Feb 22, 2012 | 12:26 PM
robert miller's Avatar
robert miller
If only that it may just be from the last oil chg. Start it up let it run for a few min,s put a newspaper under at both spots then you will know.. No not the normal for a 30,k miles but it being a 1999 rubber does go bad plus look at that side of V/cover bolts see if they are good and all these car are bad for a leak if they get loose....Robert
Old Feb 22, 2012 | 01:06 PM
Binski's Avatar
Binski
I had a situation similar to yours. After the car sat for 2 weeks or so I would see a couple of oils spots on the garage floor. Driving at least every 4 or 5 days took care of the problem. Also using the Mobile 1 for older cars (I forgot what its called) may have helped. I assume this has more of an additive which helps older seals.
To Oil leak
