replaced the clutch
I let the clutch out until I can feel it grab a little, just enough that the car moves forward slightly, then I smoothly add power while simultaneously releasing the clutch all at once. If I try to release it slowly while adding power it will chatter as you describe.
For most applications other than described above, the LS7 clutch is a great choice.
I'm right there at 522/496. Bumper-to-bumper traffic and parking lots are excruciating.
I always used to laugh when a NASCAR guy or some other big hp race driver would stall the car in the pits, especially if he was trying to get around a guy pitted right in front of him. I'm not laughing anymore.
Maybe the good thing is that if my car ever gets stolen the thief won't make it two blocks.
Don't fall into the trap of using momentum of the engine and flywheel to accelerate.
For less wear, an ideal takeoff involves low RPM and short duration of clutch use.
From an idle, apply more throttle than you normally would, but use the clutch to keep RPM low.
When done right, you will have a smooth, brisk takeoff with very little time on the clutch.
This has worked well for me. Off hand, these are the cars I can remember recently driving. All of them I could take off quickly while keeping RPM below 1300.
2002 Trans Am with Torquer V2 cam, aluminum flywheel, and SPEC Stage 2+ clutch
2007 Evo IX
1993 Jeep Wrangler
2011 Hyundai Accent
Obviously, with an extremely grabby clutch, it's going to be a pain in the ***. Do what you can while adhering to the general principle as much as possible.
2007 Evo IX
1993 Jeep Wrangler
2011 Hyundai Accent
Also, your not supposed to slip it during break-in, it causes glazing on the flywheel and will slip at high rpms.
I have DF and though the pedal pressure is a tad higher than stock. It engages very smoothly. I've had mine for many, many years now. It replaced factory stock clutch and I twisted a tranny input shaft with it doing 5000rpm drops at 70mph. Just loved doing 100ft burnouts on the freeway. But, now that I have a hardened input shaft no more worries.
I'm sold on Centerforce DF ... This is the fourth car I've had one in. They
