Btw, there's no difference between the Black vs. Red. Same urethane used in each, only the color is different. I did a quick look and Summit seems to have decent prices, but like I said, shop around. Some places will try to screw you on the pricing.
do i need 2 of these bushings? like front and back or just one. sorry but i really dont know much about these vettes and there drive train i was an fbody guy and everything was so much simpler
I've had mine installed for approx 13,500 miles now. They were specifically inspected when I had my new motor installed in January and they were fine. I also have a ceramic-coated 1/4" thick tunnel plate installed as well so I haven't had any heat issues at all.
ok and what would you suggest replacing it with then?
The Drive Shaft Shop makes some as well, but their design (and cost) is different. Of course you can also step up to a Pfadt carbon-fiber driveshaft for $2000 or an ECS u-joint based driveshaft for maybe the same price.
what Kit are you getting and why are you replacing the clutch at 53000. I have 47000 on mine and it seems fine. Are you having trouble or just upgrading?
it wont hold a launch over 3200 rpm on et streets at the track bone stock. so i went with the full drop in kit for a c5 level 3 monster. also i might be getting a d1 sooner then originally thought
