C5 caliper color?
Old Feb 26, 2012 | 10:43 AM
Corvette03051's Avatar
Corvette03051
Default C5 caliper color?
Any one know the name of the factory paint color to use on a standard c5?
Old Feb 26, 2012 | 10:57 AM
cal45's Avatar
cal45
Not sure if they are actually painted. If you are going to make the effort to re-paint, red is the way to go.
Caliper before
Calipers after
Old Feb 26, 2012 | 11:21 AM
GCG's Avatar
GCG
You may want to take a look at this thread
Old Feb 26, 2012 | 07:23 PM
Corvette03051
Thanks but I've had the big brake cars and see no reason to turn my car into something it's not. It's still a standard brake
Old Feb 27, 2012 | 10:57 AM
Corvette03051
Default caliper color
all worthy ideas, but does any one know the name of the original caliper color?
Old Feb 27, 2012 | 11:21 AM
jrose7004's Avatar
jrose7004
I believe that they're not painted at all from the factory but rather just bare metal.
Old Feb 27, 2012 | 12:06 PM
c4cruiser's Avatar
c4cruiser
For a color, you should be able to use any auto spray can paint in gray. If you are intending to take the calipers off, take them to a powdercoating shop to see what color shades they have that are close to the OEM gray color. Powdercoating will last much longer than paint and will resist brake dust. You will have to remove the pistons, seals, and bleed screws but that's not a big deal to do.
While the Z06 calipers are red from the factory, there is no difference at all between the standard caliper and the Z06 caliper except for the color.
Old Feb 27, 2012 | 01:09 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
The Z06 has the same calipers - only they are red from the factory. Not bigger, just red.
Also, the factory base brakes are BARE ALUMINUM. No paint, no powder, no anodizing. That's what bare aluminum looks like if it never gets polished in the first place.
Old Feb 28, 2012 | 06:58 AM
Corvette03051
Thanks for the help. So bare aluminium is what I should look for. They look terrible now.
Old Feb 28, 2012 | 07:20 AM
m6 c5's Avatar
m6 c5
A little steel wool and some cleaning agents will make them look brand new again.
Old Feb 28, 2012 | 10:38 AM
doje's Avatar
doje
Or, if you're hell bent on painting or powdering them, contact Mike the Powder Coater and ask him if he can mix up some powder that looks like the stock bare aluminum color. I'm sure he could. Of course, it would be like putting a wood patterned shelf paper over your mahogany cabinets.
Old Feb 28, 2012 | 04:05 PM
Corvette03051
Default good ideas
Thanks for the many good ideas. I just don't want to change the original color. I'll try the steel wool first, then Mike.
Old Feb 29, 2012 | 10:25 PM
bighank's Avatar
bighank
Default Red brush on Duplicolor Caliper Paint is the way to go
Did that several years ago when doing all around brake pad replace.
Secret is several coats of paint about 20 minutes apart until the calipers are not showing any bleed thru. Did about 5 or 6 coats and let it dry a day. Put on pads and touched up any areas scraped or scuffed. Topped off by using white paint on the front Corvette letters. Still look good years later. Original calipers looked really grungy before the paint job.
To C5 caliper color?
