Is there a thread or link that has instructions with pictures on how to lower a C5 on stock bolts? I tried a search but found nothing.Thanks for any help.2001 vert.
FRED
It is not a simple job if you have the F45 option. I believe you will need to remove the front shocks or at least the lower bolts to gain access to the spring bolt.
FRED
Don't have the F45 suspension, but still took the shocks loose to have better access to the top of the 10MM bolt head.
