LS-1 lifter failure
It sounded like too much lash on one lifter. Something is wrong I was thinking. I pulled alongside a van and rolled the window down to hear the echo. Sure sounds like a lifter. I decide to get her home as quickly as I can. In just another few minutes the sound is an order louder and I fell a noticeable shake in the engine like as though I was losing a cylinder. A few minutes later the noise is louder, the shake is stronger, and the oil pressure has dropped to 20# at 2200RPM.
Arghhhh...
Time to walk the plank me Bucko.
This be embarrassing as well as worrisome.
By the time that I get back to the house the oil pressure is down to 10 PSI. The shake is significant to the point of a lost cylinder and the noise is loud enough to notice during conversation.
I'm thinking catastrophic cam-lobe failure.
Damnitalltohell.
I pull the rocker cover and find that one rocker shaft set is loose and one push-rod seems to be setting too far down in the cavity. Like a cam-lobe has wiped.
Oy vey...
I pull the head and find that the lifter has failed but the lobe looks fine. The roller shaft came loose and wore a groove into the lifter bore.
http://millam.tackitt.net/Lifter%20Bore.jpg
The lifter shaft failure
http://millam.tackitt.net/Lifter%20Shaft%20Failure.JPG
OK. Not so bad as I feared.
Seeing as I have pulled the engine down this far I might as well pull the other head and put the RHS 54225s on.
Sigh... ;-)
Arghhhh...
Damnitalltohell.
Oy vey...
Sigh... ;-)
I have seen mention of the LS7 lifters as an upgrade but a web-search didn't give me an answer as to just why they are an upgrade.
