Gears: 3.42 or >?
Old Mar 7, 2012 | 04:17 PM
StatmanRN's Avatar
StatmanRN
Default Gears: 3.42 or >?
Since it looks like rebuild time for the rear, considering upgrading to some C6 parts and possibly a ratio change. [01 m6 STS Turbo]
Anyone gone deeper and regretted it? With the .5 OD, the dif with 4.10 is ~300 RPM @70. Maybe 3.73/ 3.90? Traction might be worse but it would definitely turn on faster.
Is the 3 rib Zo6 case that much better?
OR: While the trans is out, upgrade to M12 with better ratios and stay with 3.42 or 3.73?
Thoughts?
Old Mar 7, 2012 | 04:51 PM
sabastian458's Avatar
sabastian458
There is a gut in Atlanta selling his M12 trans for $500. I think the gear ratio in the Z06 are quick enough and could not imagine changing my rear diff gear to something lower.
Old Mar 7, 2012 | 05:25 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I'm running 3.90's along with an RPM Level V configured as an M12. This set-up has totally transformed my mostly stock LS1. I love this combination. It makes 6th gear a driveable gear, meaning that I can pull out and pass someone at 70mph without downshifting.
Around town - I find myself in a higher gear than I used to, but that is not a bad thing. Overall - I am very happy with this set-up!
Old Mar 7, 2012 | 06:08 PM
3.73s or 3.90s would be a good upgrade.
Old Mar 7, 2012 | 06:49 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
Yeah, but the ops car is turbo'd. I doubt he has any problems now with passing anyone in 6th.
I'd recommend staying with 3.42s or upgrading to 3.73s at most. The M12 gearing was designed to get the most out of the the higher RPM range of the LS6. Cammed M6 cars work great with 3.90 or 4.10.
But since you've gone the FI route, that extra torque in 1st gear could be insane with lower gearing and an M12. You have to decide if that's what you want.
Old Mar 8, 2012 | 10:06 AM
MStrahan's Avatar
MStrahan
I'm running 3.90s in my 04Z and along with that I've had a touch of head work done along with a mid range cam and bolt ons. My Nitto Invos CAN NOT hold traction. I can certainly drive in the city but I have to pay attention to my right foot at a stop light. It's made the car a little more difficult to drive since there is so much power so quickly. BUT I wouldn't change it at all. The small trade in ease of driving was worth it to me to get into the power band at an instant.
Overall I couldn't be more happy with the change, but since your turbo'd anything over 3.73 w/M6 could be interesting to drive to say the least.
Old Mar 8, 2012 | 11:10 AM
SVTBAIT's Avatar
SVTBAIT
2015 C5 of Year Finalist
If you have FI, I really wouldn't bother with gears. It's us NA guys that need gears.
Old Mar 8, 2012 | 02:19 PM
FLrealty's Avatar
FLrealty
Old Mar 8, 2012 | 05:54 PM
StatmanRN's Avatar
StatmanRN
The lag on the BW Bullseye turbos is not bad compared to a lot of complaints you hear about the STS kits, full 10# at 3500. Thinking that the gear or the lower ratios in the M12 [Not both!] would help it hit harder and faster. But yep, traction may be an issue!
I love the kick in the a$$ of lower gears and have always found them a great bang for the buck. But I have tended to go too far in the past. My Monza has 4.88s, a 700R4 4000 stall converter and small blower. Wonder why it wont hook...?
Old Mar 8, 2012 | 07:43 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Old Mar 8, 2012 | 10:48 PM
itzza427's Avatar
itzza427
Sounds like your turbo and an M12 would be a good combo!!
To Gears: 3.42 or >?
