do i need to bleed the system..
Old Mar 12, 2012 | 05:22 PM
akamam98's Avatar
akamam98
Cruising
Default do i need to bleed the system..
98, C5,, replace coolant jug, temp goes up to 218. before it didn't get over 198, do i need to bleed the system..tks
Old Mar 12, 2012 | 05:43 PM
ALLEGRO's Avatar
ALLEGRO
I would say YES.
When I replaced the coolant, I had a heck of a time getting the air out. It took several "burps" to get a consistant temp reading.
Do a search and follow the instructions. It is not that difficult.
Old Mar 12, 2012 | 06:38 PM
n8dogg's Avatar
n8dogg
Just the jug? Did you drain the coolant prior to? If you did NOT drain the coolant and removed and replaced the jug, then I would say NO. If you did drain the coolant, YES.
Here is a tip for you C5 guys trying to bleed the cooling system. Fill the engine with coolant with the upper radiator hose .
Old Mar 12, 2012 | 06:57 PM
hotwheels57's Avatar
hotwheels57
A water surfactant (REDLINE Water Wetter) and raising the front of the car helps as well...
To do i need to bleed the system..
