which fluids should i change
Old Mar 13, 2012 | 08:55 AM
robsciam's Avatar
robsciam
Default which fluids should i change
Hi guys my name is Rob and iam embarrassed to say that ive only changed my motor and blower oil in the last five years of ownership. What other fluids {rad.etc} should i look into changing when i bring my car in for service.
Thanks Rob.
Old Mar 13, 2012 | 08:58 AM
TOPCATHR's Avatar
TOPCATHR
depending on miles trans, rear, anti, brake, clutch cylinders.
Old Mar 13, 2012 | 08:59 AM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
Thanks Rob.
Being that your supercharged I would test the coolant and change if necessary. There is debate whether you should change differential and trans oil. From the factory they are good to 100k, I changed mine for cheap insurance tho.
Old Mar 13, 2012 | 09:12 AM
robsciam's Avatar
robsciam
car has 25k miles
Old Mar 13, 2012 | 09:24 AM
SaberD's Avatar
SaberD
coolant flush every 5 years, so you are due on that one.
you should also do the brake and clutch fluid every 5 years, so do those too.
other than that, with 25k miles, you shouldn't need anything else.
To which fluids should i change
