Window Valet Problem
Old Mar 13, 2012 | 11:18 AM
raydawg357's Avatar
raydawg357
Default Window Valet Problem
Received my window valet a week ago, installed it and everything worked as advertised. Had a turn signal bulb blow yesterday and after I replaced it, the valet stopped working. I removed it to try to reinstall it, but no luck. It won't give me the 3 initial chimes to begin program mode. Any advice is appreciated.
Old Mar 13, 2012 | 11:21 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Make sure you are entering the code to program it. It should work without any programing at the default.
Also make sure your battery is ok.
