SLP Blackwing Question
Mar 14, 2012 | 11:22 AM
I just bought SLP BlackWing for an 01 Z06
I was previously running an AFE filter with AFE PowerDuct.
AFE has the MAS going right into the filter, then that attaches to the power duct.
SLP says I should use my stock connector.
Can I use the AFE PowerDuct and SLP filter? Can I force my MAF into the SLP filter directly?(seems like a tight fit!)
Please help
Mar 14, 2012 | 11:53 AM
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I would install the Blackwing as per the instructions, They spent a lot of time to come up with the best set up for the filter.
Mar 14, 2012 | 01:35 PM
What He said
Mar 14, 2012 | 01:46 PM
Quote:
Originally Posted by
C5Wolfe
What He said
I understand - but I find it hard to believe that you can get a blackwing air filter and only be able to use the stock air duct? Does that make sense to you guys? The stock air duct is small compared to the AFE. I thought the more air the better???
Mar 14, 2012 | 03:56 PM
if that is what you are going for a vararam would have made more sense.
Mar 14, 2012 | 04:38 PM
Mar 14, 2012 | 06:33 PM
Mr.Bill
About the only way you will know whether you can do it the way you describe is just try it, but I think I would stick with what Blackwing suggests.
Mar 14, 2012 | 08:00 PM
Oldtimer
Why did you decide to change? Was the AFE filter damaged? I had to use my stock maf adapter on the power duct because it was too big for my 99. The AFE filter that came with mine was a tight fit, if it were any larger I would have had to cut some off of the power duct.
