Floor Jack
Old Mar 18, 2012 | 04:07 PM
awfink55's Avatar
awfink55
3rd Gear
Default Jack Stands
Hi Guys,
A word of caution, buy the best jackstands as possible. I was using a set from Harbor Freight on my Hyundai Vera Cruz SUV to rotate the tires. Luckily I wasn't under the truck when one jack decided to strip/break it's pawling pin and the truck quickly ratchet down. I used the same jacks on lighter cars without a problem. They were rated for that heavier weight class, but, I won't trust them with sometime heavy. I'll replace them with a heavier rated pair. AND, always remember to use stands and NOT to rely on your jack alone when under your car. Sometime I threw a couple cement blocks under, just in case I'm doing some tugging on rusty bolts. Just My Two Cents........Art Fink
Old Mar 18, 2012 | 10:37 PM
C5Enthusiast's Avatar
C5Enthusiast
I bought the COSTCO low profile jack and absolutely love it...It weighs a ton, though.
Old Mar 19, 2012 | 01:25 AM
soggysailor's Avatar
soggysailor
got the same one in black. Great value!
Old Mar 19, 2012 | 02:29 AM
BOUT X's Avatar
BOUT X
Corvette Cowboy
Just remember you get what you pay for cheap price cheap jack I bought one of these about 20 yrs ago and it works great not one problem ever. Hein-Werner Service Jack – 2-Ton, Model# HW93642 in 2-3 pumps it is 24" up in the air and I trust it with my life.
Pops
Old Mar 19, 2012 | 04:05 AM
SoDiezl350's Avatar
SoDiezl350
as well.
Incredible jack for the money. I also use a HF lightweight racing jack as a secondary jack.
Old Mar 19, 2012 | 10:57 AM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Since I am constantly taking my jack with me to races, weight is a major factor. The lightweight aluminum race jack from HF is perfect for my needs - with the locktite mod as mentioned on page 1.
Old Mar 19, 2012 | 12:43 PM
jimb100's Avatar
jimb100
Originally Posted by doje
A HUNDRED POUNDS?!?!?!?!!!
I just bought the same one and it is heavy. It is steel rather than aluminum but it is the lowest profile and slides under the jacking pucks easily. It also raises the highest, almost two feet with just a few pumps.
Having the choice of handle pump or foot pump is nice and having the release on the handle is a nice feature.
If I needed to take a jack to the track, this wouldn't be the one but to leave in my garage the weight doesn't matter much.
At $129 it not the cheapest but it seems to be very solid.
Old Mar 19, 2012 | 01:18 PM
ljorges's Avatar
ljorges
How low does jack need to be to fit below the jacking puck? I know that some guys drive up on boards to increase clearance under car but I'd rather not do that. (Car is at stock height - not lowered).
Thanks,
Les
Old Mar 19, 2012 | 01:48 PM
doje's Avatar
doje
A couple other notes on the Harbor Freight jack...
I had an (overly) lowered car and still couldn't fit the jack under the car. I removed the "cup" and dremeled off the little lip that remained. This gives a lot of extra clearance.
If you go on ebay and type Harbor Freight Jack, there are tons of coupons available for a dollar (assuming you don't already get the catalog yourself).
Last item is general - if you get the (frame savers? rocker rails?) that go under your rockers to protect you from hitting speed bumps, you can use these to jack on and never have to worry about pucks.
Old Mar 19, 2012 | 07:29 PM
retired08's Avatar
retired08
Default jacks?
First, I used to work for Sears and thier jacks are garbage...I have one from Harbor Freight, an aluminum, lightweight and "fast action." Use it all the time. It cost about $100.00 but go on sale all the time for about $60.00....
Old Mar 25, 2012 | 05:37 PM
BOWTYE8's Avatar
BOWTYE8
This has been my weekend Jack. Pretty much done with it as its it startign to leak bad.
http://www.sears.com/shc/s/p_10153_1...9&blockType=G9
Here is a jack I am looking at to replace the sears.
http://www.harborfreight.com/automot...ump-68051.html
Thoughts/user experience on this one.
Old Mar 25, 2012 | 09:13 PM
portsider44's Avatar
portsider44
Hard to beat the HF light weight jack, has head up good over the years, only thing to add is som foam padding like they use for resid/comm a/c.
Gives a little peice of mind when jacking
Old Mar 26, 2012 | 09:06 PM
  #33
Rexde1's Avatar
Rexde1
I just bought that Harbor freight two ton aluminum jack for 160.00 it is much lighter than my 1.5 ton sears jack at about 45 lbs. It also pumps up faster.
Old Mar 27, 2012 | 05:43 AM
  #34
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
This is the one I got from O'reilly Auto Parts. It works great and it fits under the car even with the jacking pucs in place.
•Lift Range: 3-1/2 To 14-3/4 Inch
•1-1/2 Ton (3,000 Lbs.) Maximum Capacity
Their site shows the price as $129.00 but I got it on sale for $89.00
