brake light on
Old Mar 19, 2012 | 01:00 PM
DIABL0's Avatar
DIABL0
Default brake light on
When i accelerate in any gear at any speed my brake light comes on on the dash. Anyone else have this going on or solved this issue?
Old Mar 19, 2012 | 01:05 PM
Kevin Kuse's Avatar
Kevin Kuse
Brake fluid Low? E-brake handle all the way down?
Old Mar 19, 2012 | 01:07 PM
DIABL0's Avatar
DIABL0
i will check the fluid, the e-brake is all the way down. i just had a tune up and bcm fixed could any of this cause the problem?
Old Mar 22, 2012 | 04:48 PM
DIABL0's Avatar
DIABL0
brake fluid was low, when i gave it gas it would move to the back of the bottle. I filled it up and now is golden. Thanks for the help.
Old Mar 22, 2012 | 05:19 PM
Kevin Kuse's Avatar
Kevin Kuse
Low fluid level can be from normal pad wear so they may be getting thin! Or a leak! So it is worth looking into ether way! Be Safe!
Old Mar 22, 2012 | 05:26 PM
DIABL0's Avatar
DIABL0
When i got my tuneup they said i had some real thin pads up front.
Old Mar 22, 2012 | 06:13 PM
ALLEGRO's Avatar
ALLEGRO
Dang it, I was hoping to get this one.....
I knew it HAD to be low fluid or a sloppy e-Brake lever.
To brake light on
