depo headlights and HIDs
Old Mar 20, 2012 | 01:09 AM
ckim34's Avatar
ckim34
Default depo headlights and HIDs
Hey guys I had a quick question.
I'm looking into getting the depo headlights for my car but it says that modification might be needed to add HIDs to them. Anyone have any insight?
Thanks!
Old Mar 20, 2012 | 01:24 AM
Qwik01's Avatar
Qwik01
Thanks!
I added hid's to mine and no issues with fitment of the bulbs in the high or lows. Go with a set of 55watt from ddm.
Old Mar 20, 2012 | 01:55 AM
ckim34's Avatar
ckim34
awesome. thanks qwik01!
Old Mar 20, 2012 | 01:58 AM
ckim34's Avatar
ckim34
oh and did you have any issues with the DRLs? I had someone else tell me that the DRLs might not work?
Old Mar 20, 2012 | 02:48 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
No problem with anything running HID DEPOT lights.
Old Mar 20, 2012 | 05:03 PM
ckim34's Avatar
ckim34
thats a mighty fine looking ride!
Old Mar 20, 2012 | 05:38 PM
16Again's Avatar
16Again
Thank you
Old Mar 20, 2012 | 06:54 PM
Qwik01's Avatar
Qwik01
No issues
ps- make sure to grab a hi-4 harness from radio flyer. It allows you to run your highs and lows at the same time.
Old Mar 21, 2012 | 08:08 PM
Spohnman's Avatar
Spohnman
Default Light Alignment
I installed those in my 99 but I kept the normal bulbs. One thing I am having a problem with is that the lights are pointed pretty high so I blind people when I am behind them and I light up the over-highway signs. Does anyone have any insight on the easiest way to adjust them? Thanks!
Old Mar 21, 2012 | 10:41 PM
Qwik01's Avatar
Qwik01
Adjust them to the lowest setting. The way it comes I was lighting up the top of the trees on low beams. Oncomming traffic was not happy at all that night. The lowest setting seems to be perfect and keeps the cut off out of people's eyes.
edit: You adjust them by the phillips head screw that is onthe bottom of them.
Old Mar 21, 2012 | 11:28 PM
Spohnman's Avatar
Spohnman
Default Adjustment
Great thanks! I am actually at school right now and won't be home to look at them until tomorrow and now you have me curious....Do I have to take them back out to be able to get at the screws?
Old Mar 22, 2012 | 12:05 AM
Qwik01's Avatar
Qwik01
All you have to do it remove the access panels under the parking lights. If you shine a light up there you will see the screw in the bottom center of the headlight. Or you can just put your arm up there and feel it. I can't remember which way makes it go down so you might just have to turn your lights on when adjusting. I would adjust it all the way down if not maybe a turn or 2 higher at most. Anything more than that and its too high. Atleast on mine.
Old May 24, 2012 | 07:39 AM
alonzomerrill's Avatar
alonzomerrill
You will need to use depo headlights in your car because it has law beams. This modification will solve your problem. You can also choose low voltage bulb in your car. Do you know about depo headlights?
Old May 24, 2012 | 09:27 AM
jpalamar's Avatar
jpalamar
I was really looking at the Depos myself and couldn't decide if I like them... I saw red C5 and the inside housing was body color matched and it looked amazing. When my gears finally strip I'll be ordering a set.
Old May 24, 2012 | 09:54 AM
RIPPENIT's Avatar
RIPPENIT
Default Here are mine no problem with hids
Old Sep 8, 2012 | 12:48 AM
32degreedude's Avatar
32degreedude
6th Gear
Default harness
No issues
Please tell me about hi-4 harness and radio flyer.
Old Sep 8, 2012 | 07:42 AM
la vett girl's Avatar
la vett girl
http://forums.corvetteforum.com/c5-z...available.html
To depo headlights and HIDs
Old Oct 14, 2012 | 09:54 PM
Bumble Boogie's Avatar
Bumble Boogie
From: River City USA, East of the Mississippi Peoples Republic of Illinois
Default Low profile head lights
I purchased a set of head lights from Mid America Motor Works that do not flip. What do I have to do to install them. Some say I have to remove the front bumper. How much hassle is it to remove the front bumper and do I really need to remove the bumper for access? I have the lights but nervous about installing them. Any advice would be greatly appreciated
Old Oct 15, 2012 | 10:52 AM
32degreedude
6th Gear
I had mine done by a professional. I watched/helped and we took off front bumper cover. The upside can be, access to the build sheet when the bumper is off. Instruction were poor at best so we didn't adjust the up and down. So it cost me again to have headlights adjusted. Also installed the radio-flyer innovations? relay that allows both beam to light up when brights are selected. Not a bad job just time consuming.
Old Oct 15, 2012 | 11:07 AM
Bumble Boogie
I will be putting my "Bumble Boogie" into hibernation soon for the winter. Northern climates dictate that for owners that care about their Vettes.
I will do like you and install with bumper off and install the radio flyer kit along with the head lights and new turn signals. I will have all my updates finished by the time the Crocuses bloom, I hope.
Thank you for your response 32degreedude.
If anyone else has had the experience please share your update so we can get more ideas and learn more. That's the great thing about this forum, always learning new stuff!
