Babycar's birthday is comming up on June 18th - she'll be 13 years old, 97xxx miles.
Can someome tell me how I can get the build sheet info with out disassemblying the car?
You can order one from the Corvette Museum, but I believe you will need to order both the build sheet as well as the window sticker. If you are not a member yet this would be a good time to join.
Retrieved mine from behind the front fascia several years ago. It is rolled up and located inside the frame rail right behind the fascia. Unfortunately, you do have to take the fascia loose to get to it. Much easier to just order one from the National Corvette Museum if you want one.
