LS6 Intake
Old Mar 21, 2012 | 08:22 PM
Todds427's Avatar
Todds427
St. Jude Donor '12
Default LS6 Intake
I'm sure this has been answered before but I cannot find it. I have an LS1 intake and wish to replace it with an LS6 intake. Do I have to change out everything, i.e. TB, fuel injectors etc. or is it just a matter of changing the intake and everything else bolts up fine? Just a little more info, my intake is cracked and needs replacing (according to the dealer), the engine is stock inside with CAT backs and CAI. I have seen many threads that say to replace the LS1 with an LS6 for better performance so since I have to replace it anyway, just need to know moneywise should I stay with the LS1 or replace with LS6. Thanks for any help you can provide me!
Old Mar 21, 2012 | 09:08 PM
CPhelps's Avatar
CPhelps
The coolant pipes are slightly different LS1 to LS6, but other than that everything should bolt up. When I swapped mine over, I kept my stock TB, fuel rails/injectors, etc. and only did the intake manifold and coolant passages.
This guide covers it pretty well: http://www.ls1howto.com/index.php?article=5
Old Mar 21, 2012 | 09:14 PM
corv1998's Avatar
corv1998
It is a direct bolt on replacement . Everything fits perfect ,t-body, injectors , except the coolent lines under the manifold . I just ground the little fins off the bottom of ls6 manifold , no problem ,did not have change coolent path . Kind of simple replacement . Not a huge h.p increase ,mostly at higher rpm feels stronger . p.m if you have any questions
Old Mar 21, 2012 | 09:17 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Everything will work except as others have said, You can get the cross over tubes needed from GM, Don't grind on a good intake, Do it the correct way, It is only a few bucks for the kit.
Mr.Bill
Old Mar 21, 2012 | 10:03 PM
And it is a nice upgrade for the car.
Old Mar 21, 2012 | 10:22 PM
Robert 2000's Avatar
Robert 2000
I would certainly replace an Ls1 with an Ls6 no sense to not upgrading if it has to be apart anyhow
Old Mar 21, 2012 | 10:35 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
LS1 howto is a great source for the swap.
Now, next question is the money one. A used LS1 intake you could get for free or very close. Used LS6 intakes push closer to $300 and new ones are $500-$600. Plus the additional cost of the crossover pipes. Still, this is a decent upgrade. Doubtful you'll feel much, but if you want more power later, that's where the LS6 intake will start to shine.
And if you do buy a LS6 used, make sure you verify it first. Lots of fakes out there. Can tell by the hatching pattern and flat bottom and of course the casting number.
Old Mar 22, 2012 | 12:36 AM
slowtealz28's Avatar
slowtealz28
FWIW, when I installed mine + ported stock TB, my car ran lean and only picked up 3rwhp/3rwtq. I had the car retuned after that.
Old Mar 22, 2012 | 08:15 AM
Todds427's Avatar
Todds427
St. Jude Donor '12
You guys are awesome! Thanks for the responses, great information!
Old Mar 22, 2012 | 09:16 AM
baxsom's Avatar
baxsom
read up on the intake modification so you can still use the coolant tubes. why spend over 50 bucks to restrict coolant flow in your engine when you can remove unnecessary casting ribs from under the intake and it fit perfectly.
Old Mar 22, 2012 | 10:41 AM
SaberD's Avatar
SaberD
^^this
Old Mar 22, 2012 | 07:05 PM
Big Jay E's Avatar
Big Jay E
I thought the LS1 got the LS6 intake from the factory at some point.
Old Mar 22, 2012 | 07:08 PM
Mr.Bill's Avatar
Mr.Bill
It did, I believe it was 2001 and up the LS6 intake was used on the LS1.
Old Mar 22, 2012 | 07:46 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Old Mar 22, 2012 | 07:50 PM
hiyosilver01's Avatar
hiyosilver01
I have a 2001 coupe and how can I tell what intake I have. How can I check?
Thanks.
ALLEGRO's Avatar
ALLEGRO
Yeppers !
Old Mar 23, 2012 | 12:57 AM
Big Jay E's Avatar
Big Jay E
I have an 03, and alwaysd thought I had the LS6 intake, and I guess I do.
Old Mar 23, 2012 | 01:09 AM
yaknow's Avatar
yaknow
You are 100% correct, I twisted mine off with a good pair of dikes in less than 5 minutes and cleaned up the surface with a small wood chisel. Easy fast and clean.
To LS6 Intake
