would they fit on a standard Z06 rear wheel? (no mods to the car either)
Yes they will fit but with the 30 series sidewall they will be shorter than your stock 295/35. You'll want to make sure your front tires are sized accordingly to avoid TC/AH issues.
The rear Z06 wheel is 18x10.5. There are several forum members who have put these tires on that wheel without problems.
I have to check the diameter so the stagger will be correct
Correct. I believe you want about .5" difference minimum between the rear tire diameter and the front. Just do a search there are a million topics on this subject.
