radiator hose question
Old Mar 24, 2012 | 11:49 AM
ap3x's Avatar
ap3x
Default radiator hose question
I've never owned a car with a pressurized coolant reservoir before, so maybe this is normal, but here goes:
I noticed under the hood today that the upper radiator hose was compressed down, misshapen, kind of flat. This worried me a lot at first. I remembered about the pressurized overflow tank and went and took the cap off, and the hose expanded back close to a normal shape, but maybe not all the way.
The car was a little low on coolant when I bought it, the shop that did the inspection couldn't find any leaks. I filled it up after I brought it home (week and a half ago), and its already gotten a little low again.
Is there something weird going on here?
Old Mar 24, 2012 | 12:03 PM
BACNBLK's Avatar
BACNBLK
Definitely not normal, although it is very pressurized (no leaks), ironically my upper hose has started to leak so today is tear apart radiator hoses day!
Old Mar 24, 2012 | 02:19 PM
JM20's Avatar
JM20
Funny u brought this up. Car off in the garage I just noticed my upper hose very flat around the center. When the car is running all looks normal. So subscribing.
Old Mar 24, 2012 | 02:26 PM
Jesse Asis's Avatar
Jesse Asis
You just may be low on coolent. The system works this way, if filled up correctly with the overflow tank at the correct coolent level. When driving and vehicle gets really hot, the temp rises, water boils a little and is sent to the overflow to releave the pressure. As soon as it cools down, it sucks it back into the radiator system. If you hose is collapsing, it may be time for a new radiator hose. The hoses are long and somewhat flexible, but should not collaps like you are stating. Some guys will cut the hose ends and attach a solid metal chrome pipe for the lenght part so only a rubber end that connects the pipe to the radiator, to me that allows more points of connections more points of leakig. I perfer the solid stock hose... Good luck.
Old Mar 24, 2012 | 04:35 PM
ap3x's Avatar
ap3x
Originally Posted by 8VETTE7
Replace the pressure cap. The cap is supposed to hold pressure when it builds from the expansion cause by the coolant heating and it is supposed to allow air to be drawn back into the tank as the coolant cools and returns to normal colder state. The cap is bad and preventing the air from entering the tank so the hose collapses. Been there and done that.
Sounds good, glad there are people that have had the same problem and know the solution. Is the best place to get that part the dealership, or should I look somewhere else for a better price?
Old Mar 24, 2012 | 07:02 PM
jmliles's Avatar
jmliles
Old Mar 24, 2012 | 11:47 PM
+2 New cap should solve your problem.
Old Feb 10, 2021 | 04:51 PM
L A S 911's Avatar
L A S 911
5th Gear
Default Re: My collapsed radiator hose
THANKS GUYS, MUCH RATHATHER REPLACE THE RADIATOR CAP THAN A WATER PUMP. BTW, THE CHEVY DEALER IS WHO TRIED TO TELL ME THAT I NEEDED A NEW WATER PUMP! FOR $1500.00!!!!!
Old Feb 12, 2021 | 09:34 AM
F1Fan's Avatar
F1Fan
Definately do the cap first
Old Feb 12, 2021 | 09:56 AM
grinder11's Avatar
grinder11
You meant to say the Chevy Stealer!
To radiator hose question
