oil sensior
Old Mar 25, 2012 | 12:00 PM
billgeb's Avatar
billgeb
7th Gear
Default oil sensior
what is the best way to replace oil sensior?
Old Mar 25, 2012 | 12:12 PM
65GGvert's Avatar
65GGvert
The best way is to remove the intake. The fastest way is to use flexible extension and remove it without removing the intake. A third way is to cut a hole in the cowl under the wiper tray. If you will search oil pressure sender, you can find a video or pictorial of all three methods and make up your own mind. For the record, I couldn't get one out using the don't remove anything but the sensor method shown in the video, but others have reported success.
Old Mar 25, 2012 | 12:16 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Remove the intake and then make a relocation kit for the next time, I relocated mine and I can now change it in 5 minuets or less.
If you want a pdf file on how to make a kit send me your e-mail address in a pm.
Mr.Bill
Old Mar 25, 2012 | 12:18 PM
billgeb's Avatar
billgeb
7th Gear
Default sensor
billgeb2000@yahoo.com thanks for the info
Old Mar 25, 2012 | 01:06 PM
Mr.Bill's Avatar
Mr.Bill
File sent.
Old Mar 25, 2012 | 01:28 PM
darkstar.c5's Avatar
darkstar.c5
theres a youtube video of a guy removing this sensor with the angled socket.. but its really tight back there (TWSS)
here is the location of the sensor, with the intake moved out of the way...
IF mine needs to be replaced again (its not unheard of for multiple failures) then it will definitely be relocated.
Old Mar 25, 2012 | 07:42 PM
Jacks02's Avatar
Jacks02
Brilliant!
Old Mar 25, 2012 | 10:44 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
if you take your intake off...which id suggest, take your intake to the car wash and clean it out! it will have a slick of oil in it...well worth the $5.
Old Mar 26, 2012 | 12:01 AM
If I ever have to replace mine, I will do the relocation method - either by drilling the hole under the cowl or using the TPE relocation kit.
To oil sensior
