[Z06] Dealer Issue
Old Mar 26, 2012 | 11:03 AM
RW Foster's Avatar
RW Foster
Default Dealer Issue
I recently had my 2004 Z06 in to a local Chevy dealer for an oil change. Before they lowerd the car off the rack, they showed me what appeared to be a wet spot around a gasket on the engine end of the transmission. They said it was a leak and needed looked into.
So, I brought the car back a few days later and dropped it off for them to look at. They said it would be $600 to replace that gasket if nothing else was wrong. They later called and said it was now going to be $1400. With my BS meter pegged, I told them to leave it alone and picked it up later that afternoon.
The odd things is that there are no drip spots on the floor of my garage.
If I'm going to have to pay that kind of money to fix a leaky gasket, I think I'll just go ahead and replace the whole tranny with an RPM one.
What do ya'll think?
Old Mar 26, 2012 | 12:27 PM
bing44's Avatar
bing44
I built a couple experimental airplanes. We had to fab the fuel tank from sheet aluminum, ribs, sealer, and rivets. It was hard to get them built with no leaks. I had leaks in both of mine and was unhappy until an old timer said "If it leaves a puddle, fix it. If it just stains the tank, leave it." That is my philosophy and it worked great for me. IMHO watch for a puddle and until then don't lose sleep or spend a bunch of money on an unnecessary tranny. But what else was wrong according to the shop?
jim
Old Mar 26, 2012 | 12:36 PM
RW Foster's Avatar
RW Foster
There wasn't anything wrong so far as I could tell. I never let them tear into it. I stopped them when they more than doubled their estimate to replace the gasket. My gut instincts were telling me I was being hustled to okay work that wasn't necessary. I just couldn't stop thinking that they purposely wet that seal. Like I said, there are no spots on the floor of my garage.
Old Mar 26, 2012 | 01:32 PM
bumble-z's Avatar
bumble-z
"What do ya'll think?"
I think you need to get with other members in your area & see where they take their C5 Corvettes, when needing work.
Good luck.
Old Mar 26, 2012 | 01:45 PM
hotwheels57's Avatar
hotwheels57
As low as a Corvette is and owners (not to be confused with enthusiasts) who have someone else do their preventative maintenance, I'll bet there's a lot of '97-04 cars with oil seepage that goes unnoticed until they see evidence on the garage floor.
If you're going to have someone else do the work, expect to pay their rates. That's a good reason to have an extended warranty. Or find an independent shop to do the work for you. Maybe their rates will be less.
You can always buy the shop manuals, the tools and the shop supplies and do the work yourself. It's a bonding experience.
Old Mar 26, 2012 | 02:38 PM
IMXCITD's Avatar
IMXCITD
It could be starting to seep....sounds like your rear main seal. This happened on one of mine...and it wasn't a cheap repair...but I went ahead and had it repaired in conjunction w putting in a new clutch...so I came out better on the labor that way. don't know if you need a new tranny...but that and the clutch would be good to do under the same labor of replacing the rear main seal.
Old Mar 27, 2012 | 08:51 AM
RW Foster's Avatar
RW Foster
I do have the shop manuals and tools. I've always maintained my own vehicles. I don't have a lift, and to be perfectly honest, I don't know how to lift this car with floor jacks. I was afraid of somehow cracking the fiberglass if I tried.
Old Mar 27, 2012 | 08:54 AM
RW Foster's Avatar
RW Foster
I believe the tranny is just fine. My thought process was; if I'm going to lay out $1400 for them to pull it to replace that gasket, I might just as well have them (or some other shop) put a better one in.
To Dealer Issue
