targa top
Old Mar 26, 2012 | 06:31 PM
harvey blum's Avatar
harvey blum
Default targa top
How do I tighten down front of top????
Old Mar 26, 2012 | 06:36 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
On the windsheild side on the left and right you can lower the mount by loosing the 2 bolts on the left and right side and tapping the mount down just a bit., It doesn't take much.
Mr.Bill
Both the front and rear latches can be made to clamp down the top tighter. In the front, you need to loosen the two bolts on each latch plate. These are 10 mm bolts located at the top of the windshield, behind the plastic trim. Once the bolts are loosened, tap the whole plate down as far as you like, then tighten the bolts back up. The farther you tap the plate down, the tighter the top will be pressed down when latched. To tighten the rear latch, locate the set screw that holds the hook in place. Loosen it with an allen wrench (can’t remember the size, but it was a small metric one). Once the set screw is loose, simply turn the hook (it is threaded) clockwise as many turns as you like. This makes the effective length of the hook smaller and therefore increases clamping force when engaged. By the way, the combination of these two adjustments solved the loud tapping noise that my top was making when going over bumps.
Old Mar 27, 2012 | 02:15 PM
harvey blum
Mr.Bill
thanks a ton
Old Mar 27, 2012 | 02:44 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
^^^^this...it may take a few test fits....
Old Mar 28, 2012 | 06:50 AM
SMaster's Avatar
SMaster
I used Bill's method above on a NEW targa top I bought from a forum member. It worked great
I still have a slight leak on the passenger side and the adjustment being kind of tedious has prevented me from messing with it.
But, like I said before wasting all the bytes, Bill method works fine, just take your time.
HTH
To targa top
