sub in a vert worth it ?
Old Mar 28, 2012 | 10:10 PM
gip2488's Avatar
gip2488
Default sub in a vert worth it ?
I've been thinking about buying one of those amplified sub boxes crutchfield keeps sending me emails for. The two I looked into are both under 200 watts and fit fine in the center rear compartment. My question is , will it be worth it ? will I hear it with the top down or is it a waste of money. The two i've looked into are the infinity basslink and the sound ordance.
Old Mar 29, 2012 | 07:41 AM
raydawg357's Avatar
raydawg357
You will definitely hear it with the top down. You might even ask yourself why you took so long to add one. Crutchfield is a bit pricey, but their customer support is great.
Old Mar 29, 2012 | 07:53 AM
jdmvette's Avatar
jdmvette
Night Owl for life
hell yes.
music sounds sooooooo much fuller/richer/better with bass.
Old Mar 29, 2012 | 08:01 AM
VETSTYL's Avatar
VETSTYL
oh yes!!!!!!!!!!!!!!!!
Old Mar 29, 2012 | 08:18 AM
sfc rick's Avatar
sfc rick
Crutchfield? I looked at the website, very limited in products for the C5, and very pricey. If you want actual customer service and MANY products that fit your car call Dennis. http://doubledmods.com/ is the only place to get your stuff and question answered.
Old Mar 29, 2012 | 08:28 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
Real big difference mine came with an Alpine 10" built in where the spare goes along with a 1000 watt amp and at 60mph the sound sytem is clear and loud . Well worth it if you like the tunes . Ron
Old Mar 29, 2012 | 09:02 AM
Kman1971's Avatar
Kman1971
St. Jude Donor '12
Amp and sub are must haves for the vert. Another optioin is to go with a low porfile 4 channel amp and low profile powered sub. Both of mine fit in the center storage panel after took out the unused cd changer. Music is loud and clear and the sub adds that deep sound that is missing normally. Best of all, it is all hidden. Here is a pic of my trunk.
Old Mar 29, 2012 | 09:27 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Yes Subwoofers are ALWAYS worth it.
The low frequencies that the subwoofer creates are the type that's more likely to be felt than heard even with the top down on the highway. Wind noise is most likely to disrupt higher/middle frequencies, but you'll still be able to hear/feel the subwoofer clear as day because the lower frequencies have significantly more power behind them.
Old Mar 29, 2012 | 01:46 PM
Zorlac's Avatar
Zorlac
Yep worth it. Even in my old trail Jeep with a cheap 12 and amp it was worth it.
Old Mar 29, 2012 | 02:49 PM
VET IT B's Avatar
VET IT B
Originally Posted by Kman1971
Amp and sub are must haves for the vert. Another optioin is to go with a low porfile 4 channel amp and low profile powered sub. Both of mine fit in the center storage panel after took out the unused cd changer. Music is load and clear and the sub adds that deep sound that is missing normally. Best of all, it is all hidden. Here is a pic of my trunk.
We Illini guys think alike. I also did a sub and 4 channel amp. All hidden away in center. I can vibrate the trunk lid if I want. Much better, crisper sound and volume. A must have with a vert.
Old Mar 29, 2012 | 03:40 PM
TheRadioFlyer
Supporting Vendor
I would be concerned about cooling that amp. having the amp mounted in a confined space WITH the sub could result in heat-dissipation issues pretty quickly.
Old Mar 29, 2012 | 04:35 PM
VET IT B's Avatar
VET IT B
Got it covered. I installed a relay for a vent fan and got a new cover with a vent grill installed under the carpet.
Old Mar 29, 2012 | 06:15 PM
Chilliwack vettes's Avatar
Chilliwack vettes
Originally Posted by jdmvette
hell yes.
I made a custom sub box for my C4 vert. Only had room for a 8" but it sure made a huge difference to the sound. Lots of options for 10" subs for a C5 vert - go for it!
Old Mar 29, 2012 | 08:31 PM
mightymike140's Avatar
mightymike140
i have modded c5 vert with full exhaust, i can verly hear my stock radio...i already have way to much into this car but wouldnt mind a modest sound upgrade. any suggestions????
Old Mar 29, 2012 | 09:05 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Definitely worth the upgrade! I kept mine stealth so I could still fit my golf clubs/bag in the trunk (priorities) yet enjoy a better sounds than the stock Bose system.
You're limited only by your budget. I am very happy with my new system!
Old Mar 29, 2012 | 09:24 PM
Kman1971's Avatar
Kman1971
St. Jude Donor '12
You can spend a ton, but you can also do it rather inexpensive too.
4 channel pioneer amp: $150
Pyle Power low profile sub: $100
Wire/Amp kit: $50
Install yourself or pay a pro 2-3 hr install for about $150
Check out buy.com and ebay for great prices on all the equipment. Again, you can spend $5k and up for a State of the art system, or you can spend under $500 for a 100x better system than stock and you will enjoy it 1000x every time you are in the car, and with the vert.....again it is a must have mod for cruising in the vert.
Old Mar 29, 2012 | 09:27 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
We can easily help you with adding a sub in back
I have many many preloaded sub box options with all you will need to install as well.
Not a fan of the option you posted above myself. I can get them but would not suggest them
Dennis
Old Mar 29, 2012 | 10:59 PM
theheartbeat's Avatar
theheartbeat
Clean install,
Old Mar 30, 2012 | 05:57 AM
ZMX's Avatar
ZMX
Yes, it's worth it.
It won't take much to get good punch.
To sub in a vert worth it ?
