Headlight door issues
Old Mar 30, 2012 | 04:47 PM
kpmunt's Avatar
kpmunt
Default Headlight door issues
I bought a disassembled 02 last fall. Had been in the ditch and needed extensive replacement of body panels.
Upon installation of the headlight assemblies everything worked fine initially: on/off, high/low, up/down. After cycling them through about 6 times the open/close of the doors is not working, they are stuck open. The on/off and high/low work fine.
They give no hint of wanting to move when turning the lights on and off.
I've tried to search this problem and get a myriad of results. Taking the lazy way and looking for suggestions.
