CD Changer
Old Mar 30, 2012 | 08:37 PM
revival1's Avatar
revival1
Default CD Changer
On my 2000 Corvette the CD changer loads but won’t play. There’s no display on the radio. Any help with be great.
Thanks in Advance,
Mark
Old Apr 8, 2012 | 07:01 AM
FiberglassFan's Avatar
FiberglassFan
Sometimes this works, but not all the time...
Start the car, leave engine at idle, all electrical systems in normal operation with radio on....Now go to the trunk and open the floor over the depression where the CD player is..
Find the 'slifing panel' over the casette that carries all the CDs, and slide it open, and allow the casette to eject. Fully remove the casette of CDs, then re-install in the player box, and slide-close the cover, ALL THE WAY closed...if it is open even a tiny bit it wont work right. You should hear the mechanism clunking away inside the player now, as it looks for CDs in each slot.
After this re-boot with the car running, I have found that most of the time it works for me.....but not all the time...sometimes VERY frustrating!!
Good Luck
Old Apr 8, 2012 | 08:47 AM
JerzeyJoe's Avatar
JerzeyJoe
It happened to me once or twice. I pull out the cd case from the changer, put it back in. After it cycles through, it works fine.
Hope this works for you.
Old Apr 8, 2012 | 10:42 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The two usual causes of problems with it are 1) discs in upside down. 2) putting in the cartridge and not allowing enough time for it to cycle through all of the discs before opening the car door and starting the car. You must wait while it takes care of business otherwise you'll get an error and have to do it again.
Old Apr 8, 2012 | 11:37 AM
ksvette74's Avatar
ksvette74
worst case is there is a ch changer stereo rebuild place in newyork. just have to google it. I forget the name (saved on my other computer). I need to send one in for a rebuild.
To CD Changer
