Weld zo6 titanium exhaust
Old Apr 1, 2012 | 07:19 AM
Corvette03051's Avatar
Corvette03051
Default Weld zo6 titanium exhaust
How difficult is it to weld the pipes back on? Is it possible?
Is it expensive?
Old Apr 1, 2012 | 07:44 AM
4 KRUSIN's Avatar
4 KRUSIN
Titanium isn't that difficult to weld. The problem is that titanium welding rods are VERY expensive and most welders do not have it in stock.
I bought my Ti's very cheap because they had been cut. I phoned several welders and the answer was always the same: "If you can get me the rod, I can weld it". I finally found someone who had access to the rod. He was in the airline industry. I found him by posting in the Regional section of this forum. You could try doing the same in your area.
Old Apr 1, 2012 | 08:53 AM
Corvette03051
Default WELD Zo6 titanium exhaust
Can anyone recommend a place to go to weld the pipes on a titanium muffler close to 02035 (foxboro,ma)
thanks
Old Apr 1, 2012 | 09:33 AM
Dark-Knight's Avatar
Dark-Knight
What are you nwelding? I have slip joints in my exhaust, every thing just slides together and is held in place with clamps. Same for the Ti's i had for about 3 years...
Old Apr 1, 2012 | 09:36 AM
jrose7004's Avatar
jrose7004
I tried but couldn't find anyone in the OKC metro a few years back that could do it.
Old Apr 1, 2012 | 09:44 AM
Corvette03051
Default Weld
The pipes have been cut a few inches before the muffler
Can they be clamped? Must they be welded?
Old Apr 1, 2012 | 09:47 AM
TwoSmoke's Avatar
TwoSmoke
Once you find the Ti welding rod, you will have to have them welding in an oxygen free environment. Oxygen weakens the weld.
Old Apr 1, 2012 | 09:49 AM
Corvette03051
This sounds like a real problem. Can they be clamped instead of welded?
How long would a standard weld last?
Old Apr 1, 2012 | 10:38 AM
TwoSmoke's Avatar
TwoSmoke
By standard welding I assume you mean no shielding gas. If a titanium weld contacts oxygen during cool down then it is weakened to be useless.
Read this section on shielding gas.
http://www.millerwelds.com/resources...tanium-welding
Old Apr 1, 2012 | 06:10 PM
Corvette03051
Default Weld ti exhaust
I'm hoping I can clamp them together!
Old Apr 1, 2012 | 08:10 PM
needdlex's Avatar
needdlex
If a shielding gas is required for titanium, all you would do by using standard rods would be to make burn marks all over it and not get the metal to accept the flux.
If you were able to get it to hold initially, it would probably brek off from vibration.
As someone that does quite a bit of welding, I would recommend finding someone that knows what they are doing. I'vE only worked with steel, stainless, and some cast, but never titanium... So I can't speak from experience.
Old Apr 1, 2012 | 08:22 PM
Hammer99's Avatar
Hammer99
You should be able to with those 2 1/2" wide band clamps.
Of course it depends on where your cuts are...
Old Apr 1, 2012 | 08:38 PM
Corvette03051
Default weld
I've decided to pass on the purchase. The guy selling them thought it was an easy job. About an hour. NOT
Thanks for the advice. On with the search.
Old Apr 7, 2012 | 07:22 AM
Dark-Knight
Good decesion....
Old Apr 19, 2012 | 12:11 AM
moespeeds's Avatar
moespeeds
Ti can be tig welded pretty easily though everyone and their mother will tell you otherwise. For exhaust just cap the ends and fill with constantly flowing argon. I do it the redneck way and just crank up the argon flow on the torch and use a large cup with a diffuser. If the weld hits oxygen before it cools enough you know it as it will change a shade of purple. I wouldn't do it on a roll cage but wouldn't hesitate on an exhaust. Ti rod can be bought in small quantities on ebay. If the cut is real clean you might get away with fusion welding it, no rod needed.
To Weld zo6 titanium exhaust
