EBCM question?
Not really worth buying a used one because it may go out as well. GM should be forced to be held accountable over this.
You wont have AH, bit more importantly you wont have ABS (and that may make it a bit tricky to pass a vehicle inspection if you have those where you live as the ABS brake light will be on).
The EBCM also assists Magnasteer, decreasing effort in turning the sttering wheel at low speeds.
http://www.pc-surgeon.net/images/cfo...alfunction.pdf
Its not a given that yours is gonna go, hope it works out
I have a 2000 vert and am concerned about this problem also. Thanks to this forum I became aware of this problem. One forum member claimed that this item "may fail because of lack of use". He suggested to find an open stretch of road and say at about 40 mph slam on the breaks. This should/will activate the ECMB and you should see a message that says "abs active". I have now do this a couple of times and will continue to do so. I don't have active handling but that shouldn't matter.
Someone please correct me if I'm wrong.
There are a couple of electronic specialty shops that claim they can fix this vintage of ECBM (1998 to 2000) but it's expensive.
Here is a link to one of them.
www.autoecu.com
No not all came with A/H but they have EBCM's just not with A/H but they have ABS and T/C
(2) One of my "97s" did not have A/H If my memory is correct. Also, can you remove the ECBM or just get it programed out?
Most '97's did not and a lot of '98's too - but the EBCM or Module can be interchanged from 1997-2000 - "BUT" you can only use a NON-A/H on a NON-A/H Vette and the same rule goes for the ones equiped with A/H 1997-2000 the A/H module can be interchange only if it is equipped with A/H
NO! it cannot be programmed out!
(3) If there is a real danger of ECBM trouble causing the car to become worthless because It couldn't be fixed I may just sell it and buy another one that is not equiped with A/H If that is possable.
There are still a lot of Modules out there to be had and more plentiful are the A/H ones over the NON-A/H (like my 1998 and your 1997 you had - these are becoming more and more rare) - so no matter how you look at it you can't run from it -
Now you could get a later model Vette 2001-2004 that the modules can be repaired due to the fact that GM finally figured it out that it is not wise to sink the board into epoxy thus making it non-repairable! (plus all 2001-2004 are A/H and are interchangeable)
Suggestion:
Scour the For Sale section or look at Corvette Recycling, Ebay and other vendors and grab a good used one for your Vette and set it on the shelf in the event yours fails - I have done this and it saved my bacon -
Your Vette will continue to operate if the Module does indeed go bad - you will have brakes just "NOT" Abs, it will be like the old days like standard brakes, You will not have T/C (Will be just like turning it off at the button), and you will not have the use of A/H (if so equipped) - your ABS light will illuminate and you will get a message Service A/H etc. on the DIC - "BUT" again you will be able to drive it anywhere you want till it is fixed!
Thanks,Matt
If they did fail you it would be mandatory that GM provide replacement parts. And they do not.
Again, only the red brake light can fail you in Missouri and I would bet that's the case in all states. I did read a member here state he couldn't register his vette because of it, but I ain't buying it. He hadn't even tried the way it sounded.
I was actually looking at some muscle cars yesterday myself. I love this thing and I doubt I will ever sell it. But these things have issues they shouldn't have, IMO.
!!Mine pops 2 warnings as soon as I start up,,and the 3rd pops as I near 30mph. I live in south west Illinois,,close to St.Louis,where we have to go through emission testing. They just plug into the port and look for emission relevant codes. Been through twice and not a problem.
Thanks,Matt
661-406-7516
Last edited by madmatt9471; Apr 2, 2012 at 05:26 PM. Reason: fix phone number - 661-406-7516
Sorry about yoour issues, I have had only one electrical issue on mine and it was "ONLY" the Module that failed
and mine is a 1998!Thanks,Matt
